Bronco seats are starting to peel away
medarling
michigan
2021 bronco aport
I think I must’ve been luckiest person in the world because I think I’m the only one that has my seats peeling away on the black part in the middle. Is anybody else else having this problem?
Ford Bronco Sport Bronco seats are starting to peel away IMG_3407
Good morning. I would like to look into this seat peeling issue on my end. To get started, can you please send over a message with your VIN and estimated mileage?
medarling
michigan
2021 bronco aport
good morning my VIN 3FMCR9D9XMRA51636. My miliage is just under 29,000. Thank you!
S2800
Jason
Detroit
My back seats are starting to crack and peel also, not as bad , but same type of seats
Bill G
San Gabriel Valley, CA
My driver’s seat is showing a little scuffing on the outside seat and lower outside back from wear of getting in and out. It’s hardly noticeable when the seats are clean/conditioned, and I really can’t complain after almost four years of use. Passenger/rear seats have no deterioration (less use and my wife’s a lot lighter than me - heh, heh, heh).
Click on the Ford avatar, then start message. Send this information to them this way. Be careful sharing this information publicly.
redbucky2022
Shane
Cape Coral,FL
22' Hot Pepper Red BS
Center section is only dyed on top not through and through. It will continue to peel over time. A reputable upholstery shop can blend that area and make it look good but it will always be a problem. I put Katskin in my BB myself to avoid this issue.
… seats peeling away on the black part in the middle
Several owners have posted similar issues and turns out most had clothes with rough edges or jeans with rivets etc. which caused the “relatively delicate” material on the seats to be damaged much like your pic shows.
And some were damaged also on the ebony material.
At least one had tools in their back pocket that caused considerable damage much worse than your pic shows.
I don’t know that the material on the seats is “delicate” but in your case if it wasn’t caused by tools or something like clothes with rough edges/rivets then the seat material is not something that’s going to take a lot of wear and tear.
What year is your the Badlands and how many miles on it when you noticed the seat damage?
23k miles on my '21. Garage kept wife drives majority of time and she not heavy or chunky so little stress on seats...
Shadow makes seat look weird front center but seat still in perfect cond
Ford Bronco Sport Bronco seats are starting to peel away PXL_20240831_163455178
