Bronclahoma
Oklahoma
Well, the reveal is almost here. Ran across a MSN.com article citing Moter Trend and it mentions some things we haven't heard about here. Notably:
"so expect that the Sasquatch to come with a mix of taller tires, possibly an intake snorkel, rock rails, a roof rack, and new front and rear bumpers made for additional tire clearance and possibly a small, factory installed winch. If you’re thinking “that’s close to a Bronco Everglades,” that’s what we’re thinking, too, but for the smaller Bronco Sport. "
Messin’ With Baby Sasquatch? Ford Bronco Sport Could Get Beefed Up Off-Road Package (msn.com)
no way it would be $60….
I could see being the new top of line at around $38k-$40k…
My 2021 bronco sport First Edition was 43500 all done , I thinks 2024 badlands is now 45500.. so I guess we will see what ford has for us tomorrow. And I also put on a set of Goodyear wrangler 235/70/17 tires a couple years ago . They come in at30.03 inches .
hellb0y
Hellish
BS
Huh? A base Badlands, which is fairly equipped already, is $38.3k
Ford Bronco Sport Sasquatch Bronco Sport Teased by Ford - 8/26 Reveal! IMG_2995
A '24 Badlands Sport with all the options has an MSRP of 47k per Ford web site Build & Price.
Ford stated the 2.3T did not fit under the hood
The 2.3 has identical external size dimensions as a 2.0. They are the exact same size engines externally. The 2.3 has a longer stroke crank. That's how it gets its bigger displacement. Hop on over to the Focus forums the ST guys been swapping 2.3 cranks into 2.0 blocks or swapping entire 2.3 engines into their 2.0 cars for a long time now. There is some guy out there with a 2.3 in a Maverick like a year back.
CletusVanDam
Olympia, WA
If everything in the mullinax description is correct, it'll probably be around 50k. Just adding a 2.3 liter engine alone will make a big bump.
This is the Bronco Sport Raptor (with a different name).
I wonder if there will be exclusive colors?
Edit: I'll be surprised if Mullinax was posting something made up. That's a real dealership that I deal with all the time. They probably just screwed up and put it online early.
So what would it cost to have a longer stroke crank installed on our 2.0 ?
There are companies out there selling 2.0 blocks with 2.3 cranks because the 2.0 block is considered stronger then 2.3 block. Can also have local machine shop swap the 2.3 crank/rods/pistons into 2.0 block. Googled it the Focus ST guys have been doing the 2.3 crank into 2.0 block for a long time. This trail is already burned and discussed all over the web for at least 10 years now.
