Review of 21 Badlands off road capabilities
bstn rnr
JP
Tennessee
I just spent a month in the Moab, Utah area and had the opportunity to take my 2021 stock Badlands on some epic road trips.
Some areas I hit were: Sections of the White Rim road in Canyonlands, the road to Paul Bunyons Potty in the Needles District, the Gemini Bridges Road, the 4X4 road in Arches from Sand Dune arch to Balanced Rock, the road to the Secret Spire near Canyonlands, Cathedral Valley loop in Capitol Reef, the road to White Pocket, Arizona and the very rough road to Toroweap Point on the Grand Canyon North Rim. Many of these are rated high clearance 4X4 only.
I am happy to report the Bronco did excellent. I used nearly every mode but mostly stayed in Normal. The Sandy Mode got me through some very deep sand to White Pocket. In fact, when I stopped at a trailhead beforehand to use the bathroom, a girl with a Tacoma asked where I was going. When I told her, she expressed doubts the Bronco could handle the deep sand. It did. I will say I kept my momentum going so as not to get bogged down.
At Toroweap and other roads, there was some rock crawling required which the Sport handled very well. I also plowed through mud on a couple of occasions without a problem.
I did tear a small piece fabric liner beneath the BS which illustrated the only limitation I found: its clearance. A couple of times I had to turn around because the rock drop-offs were too steep and I feared getting the Bronco high centered or damaged. I also got some "pinstriping from bushes alongside the roads but it all buffed out. The Bronco Sport is not a Jeep and will not go some places a Jeep can. But I found those places to be far and few between.
On the 4X4 road from Sand Dune Arch to Balanced Rock, I felt it was dicey in spots but came out just fine. I went on the same road a few days later in a friend's Jeep and it beat the heck out of me. I had a sore back for two days. The BS is a much more pliant ride.
There are a couple of things I will change to my Bronco before I go out there again. I will at the least lift the front wheels by 1.5 inches, install a front bumper bashplate, and replace the fabric liner section with a metal skid plate
There was a rock climbing section on the Gemini Bridges road that I did not think I could clear. I saw a side by side go ahead of me and decided I'd give it a try. Again, the Bronco performed great. When I got the to the bridges, I saw the family in the side by side and said "Well, that was fun." The wife told me she couldn't believe such a pretty car was able to get there. Haha.
Ford Bronco Sport Review of 21 Badlands off road capabilities IMG_1798
Ford Bronco Sport Review of 21 Badlands off road capabilities IMG_2423
Ford Bronco Sport Review of 21 Badlands off road capabilities IMG_2615
Ford Bronco Sport Review of 21 Badlands off road capabilities IMG_2930
The most limiting factor of the Badlands off road performance is the driver.
Good on you for doing things with the Badlands most will never do.
sajohnson
Sherman
MIDDLETOWN, MD
The sign says, "Know the difference" but the NPS has an odd take on it:
"What is the difference between a 4x4 and All Wheel Drive (AWD) vehicle? True 4x4 vehicles have a 'transfer case' in the drive-train that puts full engine power to the front wheels. All Wheel Drive (AWD), common on vehicles like crossover SUVs, relies on a 'differential' to send variable power to each wheel. AWD is good on level roadbeds in low traction conditions like snow. It is not designed to fully power the front tires in off-pavement rugged situations. For example, if the road goes up a steep hill and there is a lot of loose rock in the road, fully powered front wheels are needed to rotate strongly and pull the vehicle up the slope. AWD cannot do that very well and may fail."
https://www.nps.gov/para/planyourvisit/4x4-vehicles-and-off-pavement-travel-safety.htm
Huh?
Well, I guess we should stay on "level roadbeds" where we belong... :cool:
Dadio
Rob
Cobourg, Ontario
2023 Ford Bronco Sport
I think the drive system of the Badlands is more than a simple AWD system.
From media.ford.com : re Bronco Sport Badlands specs
“4X4 system with liquid-cooled PTU, disconnectable driveshaft with 4x4 lock, and dual clutch RDU with differential lock feature”
sajohnson
Sherman
MIDDLETOWN, MD
There is some 'writer's embellishment' there, but yeah, the BS BL has a nice system. It performs well off-road and on the 'roller test' -- where if any one tire has traction it can move, forward or reverse.
It's very impressive, but it's not "4WD" or "4X4" -- not according to any common definition of 4WD. Ford probably likes using "4X4" because it makes for better marketing. That's not criticism of the BS BL, just an observation. If I was not impressed by the AWD system in the Badlands I would not have bought one.
AWD is actually more useful for most drivers, who rarely, if ever, do any serious off-roading. There are no restrictions on when it can be used (in "Normal" mode). Old school part-time 4WD can only be used in low traction conditions. If a road is completely snow covered it can be engaged, but not on wet or dry pavement. There is automatic 4WD which can be left engaged.
There is no single definition of 4WD, but typically it includes a transfer case (part-time) or locking center diff, and low range gearing. More serious systems have true locking diffs, front and rear.
So the BS and BS BL are not 4WD, but they do have a very capable AWD system -- especially the Badlands with the dual clutch RDU. That's not what is meant by a "locking rear diff" but it functions the same way, as long as the clutches do not overheat.
Also, the front is open and relies on the traction control system to redirect torque. That works well in most situations, but it is not the same as a locking front diff.
None of the above is in any way meant as criticism -- I'm only pointing out that Ford's marketing is misleading. As a practical matter, none of the above matters to the vast majority of BS/BS BL owners, it just bugs me when mfrs are not honest.
Dadio
Rob
Cobourg, Ontario
Interesting and thank you for the clarification ! Great insight into the difference. It brings back memories when I had a brand new 1980 Scout back in the day and remember having to go outside the lock the hubs, and then getting it into range .. sheesh !
Amazing photos! Thanks for sharing your adventure with us!
Winds of Change
Chicagoland
There are a some of us that truly know just how capable a Badlands Bronco Sport is! A little bit of lift, some extra armor and the right tires. Look out lol.
OP, great write up. Moab is magical. The BSBL is a little beast, but like Clint Eastwood says “ A man’s got to know his limitations”
The biggest limitation is the ground clearance followed by the gearing in my opinion. It’s amazing what a little more clearance and some lower gearing can do for you. But, there’s a ton you can do with it just out of the box. Not sure who at Ford thought felt made good bash plate material!
