Cargo cover option
If your vehicle does not have the Cargo Management System (CMS), consider this:
Saw a post that this “cargo cover system works. Easy to retract for taller items. No need to apply adhesive or drill any holes.” (Those are not my words - The owner that posted the info said it fits on his 2023 Bronco Sport OB and also said have to be gentle using the cargo cover as he did not use any adhesive for the install)
$116 on Amazon with 10% off. Maybe will be less for the July 16-17 Prime Days.
https://a.co/d/05ftYLdH
Ford Bronco Sport Cargo cover option IMG_6029
Interesting but for $114 I find it less expense to simply throw a black blanket over any rear cargo.
My thoughts too but I have the CMS
Some might like the option of having a cover
MannySport
Emmanuel
Toronto
Bronco
who will be the first to install this and post photos? I've been thinking i need one.... I had it on my BMW Wagon and used it all the time.
Saw an owner post his pics. He did say have to be gentle using the cargo cover as he did not use any adhesive.
SN19745
NA
2023 Bronco Sport Big Bend
Saw a post that this “cargo cover system works. Easy to retract for taller items. No need to apply adhesive or drill any holes.” (Not my words)
Thanks for sharing this. I have been looking for a cover and this may be it
davidg4781
Have y'all seen the one on Facebook/eBay?
The guy made them and is selling them on eBay. I think it's a platform that hangs on the bag clips on the sides. The way it's mounted puts all the weight on the sides of the cargo area so it's pretty sturdy.
Sojourner
Maryland
We have the CMS, but my wife misses the retractable cover that was in our Escape.
Speaking of Escape, that is what this product fits. So it will also fit the Bronco Sport?
Exactly. The owner that posted the info said it fits on his Bronco Sport (2023 OB).
Sojourner
Maryland
Thanks for clarifying. I was so intrigued by the product that I wasn't sure about the fitment angle.
Appreciate your reply.
Sojourner
Maryland
The Powerty cover for the Escape works quite well. Not perfect, but pretty close.
The brackets (where the cover attaches to the head rest post) are the weak point being a rather flimsy bit of plastic.
The angle of the cover holder has to change, but it is functional. I used a double layer of tape so that it conformed better to the BS angle (more vertical, less angled than the Escape).
Less than $100 during the July Prime Day sale. I think it was worth it.
We have the CMS. Now, the best of both worlds.
When using, you have to pull the cover out by going UNDER the rear brackets as the rear opening is too tight above the bracket (and you'll scrape things). Same with releasing the cover from the brackets: pull back and release from UNDER.
Ford Bronco Sport Cargo cover option 1000001905
Ford Bronco Sport Cargo cover option 1000001906
Ford Bronco Sport Cargo cover option 1000001907
To be clear … you installed the Powerty cover on your Bronco Sport that has the rails for the Cargo Management System and I think the owner that I posted about in Post #1 installed the Powerty cover on his BS that does not have CMS option?
That means the Powerty cover can be installed in all Bronco Sports (with or without the CMS rails) albeit with some limitations in each case.
Sojourner
Maryland
Yup. All BS, CMS or not.
Cover sits at the height of the top of the back seat (about 3+ inches above CMS foldable shelf panel).
Ford Bronco Sport Cargo cover option 1000001909
Ford Bronco Sport Cargo cover option 1000001908
Ford Bronco Sport Cargo cover option 1000001910
