Bill G
San Gabriel Valley, CA
You have my sympathy; sitting at stop light yesterday when one in a RAV4 decided to make a right turn into the side of my BS. He slammed the brakes, skidded sideways, and missed me by a couple inches.
They are out there and they vote!
Did try 255/75R17 it’s fit but not perfectly it’s only 2mm gap while turning, it’s not a good thing in wintertime in snow and ice,
so i will go for 255/70R17 in Goodyear wrangler tires
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2047
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2050
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2049
Very nice on mine 235/70/17
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0858
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0796
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0343
dedwards0323
Dennis
Upstate SC
2021 Bronco Sport Outer Banks
Yesterday, I added these Ford Bronco Sport Door Dill Protectors. Somewhat hard to find these made for the Bronco Sport.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240522_132733
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240522_132613
dedwards0323
Dennis
Upstate SC
Today I Installed this Ford Smoke Aeroskin Hood Deflector. I found several very small chips in the hood's leading edge a couple of weeks back. :mad: Turned out it was cheaper than the aftermarket versions I looked at. :thumbsup: Only $79.00 for this Hood Deflector!
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240523_104517
Ford Bronco Sport What did you do TO your Bronco Sport today? 20240523_104526
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
Installed LED turn signal bulbs this morning. I tried 4 different ones, and shot some video with the Hazards on for comparison, and did frame grabs and cropped them to a comparable size.
Ford Bronco Sport What did you do TO your Bronco Sport today? LED Turn signal comparison 02
Ford Bronco Sport What did you do TO your Bronco Sport today? LED Taill ight comparison
The stock Halogen is on the left in each of these photos. The camera was on a tripod with a remote Bluetooth trigger. Videos recorded and screen grabs at max brightness taken.
I didn't catch that the headlights were on for some of these pictures. Every time you close the door and reopen, the headlight switch changes back to Auto mode.
I installed the Alopee 912s. I think the Alla 912s may be too bright. The reasoning for buying all these bulbs: I don't want to blind cars following.
Oddly, the largest and most expensive ones were dimmer than the stock Halogen bulbs.
I find it strange the right side Halogen appears brighter than the left side.
Omg where my computer at ?
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2088
That is a sealed connector and ECU electronic box but it is unknown how long can remain submerged before is damaged.
Likely submerged for a “short” time is ok but “too much time” is not ok. There are posts on Bronco Sport Forum showing the damage if submerged (for “too long”) but the owners did not say for how long the connectors(s) and electronic box(s) were submerged.
Rhel
Rögnvaldur
Iceland
www.facebook.com
true that’s why I did wove the electronic box in the top of the air box, little bit work yes few hours but I think it’s worth it
true that’s why I did move the electronic box to the top of the air box, little bit work yes few hours but I think it’s worth it
I think I recall you or someone moving it… did you take a video or some good pics of the steps you did?
Rhel
Rögnvaldur
Iceland
www.facebook.com
not many pics
I did use original wiring set , unplugged and moved that up and unlock many clips, moved ground wire 10cm higer
I did use also original bracket that hold the electronic box, just changed so it fits
im gonna make quick release so i will be able to get quick in the air filter box
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2087
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2086
