Curt Trailer Wiring vs Ford OEM
TNFurb
TNFurb
Nashville
Are you sure you have to have the factory wiring to get the sway control? On my BSOB I do not have the factory towing and have yet to install any aftermarket hitch or wiring, but the sway control setting is available to me on my infotainment screen and I can turn it on and off. I thought the sway control didnt have anything to do with the wiring and it was basically all sensors that are already on the vehicle??? I could be wrong.
Orangejuice
NJ
23 BS OW
^ Mine is the same way. I have a tekonsha harness and am able to turn on or off trailer sway
Kotkoj
Saskatchewan, Canada
2012 Bronco Sport
With the factory installed system sway control is automatically enabled when a trailer is connected. I believe that's the difference. The system will also notify you if there are trailer lights burnt, also it will automatically disable blis. I do believe that is only the factory installed system. The dealership installed option does not do this and neither do aftermarket solutions. Im looking into what would need to be done or if its possible to add that functionality but i haven't found anything yet. It may not be worth it.
