Fuel line inside hood weatherstrip
EARLSAYS
Earl
Houston
I attempted this tonight…I might just be tired, it’s cold, it’s dark - but I had a hell of a time, I can onlu get about a foot of hose into the weatherstrip, and it just stops….usinng dish soap to lune it up….any tips on lubricating the entire inside of the weatherstrip first? Hands get too slippery to push the hose….any tips?
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
genuinely curious what's going on here
fuel line in weatherstrip
must've missed a thread on this one
will offer this
try using semi flexible wire of thinner gauge as a fish wire
pull back the fuel line
still wonder why
Ford Bronco Sport Fuel line inside hood weatherstrip 1702952844577
EARLSAYS
EARLSAYS
Earl
Houston
will offer this
still wonder why
its supposed to help reduce hood shake at speed.
AZ_85623
2024 Bronco Sport Badlands
wireman
Murrieta
Get a piece of Romex wiring, 12 or 14 gauge the needed length. Strip the outer sheath and use any of the 3 wires.
Push it thru the weatherstrip, tape on the hose and pull it thru.
Stringer
Ontario
2021 Badlands, I removed the (ford) deflector from the hood and it stopped all vibrations.
Deleted member 6350
Just add a HoodScoop problem solved no more hood vibration,
Ford Bronco Sport Fuel line inside hood weatherstrip IMG_2547
Stradasphere
Glen
2023 Bronco Sport Badlands ; 2001 BMW Z3
I ran 3/8 OD surgical tubing in side my door seals on 2016 F250 to stop the whistling. Its softer than fuel line, might be an option
EARLSAYS
EARLSAYS
Earl
Houston
Try using 1/4” fuel line instead. It goes in easier
I did exactly that, and it worked well - improved Things a bit, I am tempted to do the same to the front and side weatherstrip under the hood to see if that helps.
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Did your 2023 BL actually come with the side weatherstripping? Curious, because I had to buy mine and add it.
EARLSAYS
EARLSAYS
Earl
Houston
no, my 2023 did not have the side pieces, I ordered them and installed myself.
Electricians have a special lube they use for pulling wires. It stays slick longer than dish soap. The also have a "fish" which is stiff wire with a hook on the end. You could push it into the tubing and tape it tight to pull it through. Know any electricians?
Home Depot sells individual wires on rolls, you can cut to the length you need.
