Won’t start
Kg5px
Kathleen
Brake pedal was hard as a rock. If you can’t budge the brake pedal, car won’t start. Dash cycled through various screens, all bad. Service recommended “hard reset“ by disconnecting battery, which worked. Anybody else have this problem or know cause?
WTF! o_O
Kg5px
Kathleen
My sentiments exactly. Bronco is 21 Outer Banks, one of the first built, 12/20.
Foad
Cincinnati
Yes still having issues. Stuck in garage. Found neutral release. Moved a feet then brakes set. Now nothing. Blocking garage door and wont budge.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
That sure sounds like a dead battery could be causing that.
Call Ford and get it flatbedded to the dealer.
Good morning. Would you privately message us with your VIN and dealer info so I can look into this concern? Thank you!
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Broncoette
Be Kind
Planet Nice
When my 2021 OB was towed out of my garage last week (see my other threads for details) the tow truck driver pulled the manual release to attempt to get the car into neutral. That set the parking brake right away which he thought was a safety feature installed by Ford. Obviously not to practical in this situation!
He ended up hooking my car up by the tow hitch and put heavy duty plastic slides underneath all 4 tires. He essentially had to drag my car out of the garage. It was painful to watch. Now I'm in limbo as my car sits at the dealer but fortunately they gave me a loaner car to use in the meanwhile.
Foad
Cincinnati
Took 3 different tow driver. But due to the angle if my garage to my driveway. I needed a regular truck ( nothing flat ). Also needed something called jump pro. But 8 hours after it started. Now await dealers findings.
Ford Bronco Sport Won’t start 20231113_170522
josharch
What was the outcome here, I have had the same issue
Foad
Cincinnati
Turn out to be my fault. When I replaced the battery. I put the tubing on before I finally tightened the battery bolts. But after putting on tubing. It wedged the wires tight enough I felt they were tight. But it wasn't so it acted like it still had an electrical issue. :facepalm:
Foad
Cincinnati
But as far as why it would unluck into neutral. Was told if it has a dead battery it won't go into neutral.
