- Joined
- Feb 4, 2020
- Threads
- 10
- Messages
- 339
- Reaction score
- 394
- Location
- Arizona, USA
- Website
- discountti.re
- Vehicle(s)
- All Things FORD
You definitely want to get this under control ASAP. Consider traps. I know some people don't like to kill animals unnecessarily, but mice will chew through the wiring of your vehicle(s). Ask me how I know...Looks like a mouse decided to nest on top of it, then chew through it! Threw out the nesting material, sprayed some peppermint spray in the engine bay as a hopeful deterrent, putting an ultrasonic pest repellent in the engine bay on Tuesday, and replacing the cabin air filter when the new one gets here.
Unless there's a trap that would be effective in the engine bay, I won't have much luck. The issue is I have to park the car outside in a rural area...You definitely want to get this under control ASAP. Consider traps. I know some people don't like to kill animals unnecessarily, but mice will chew through the wiring of your vehicle(s). Ask me how I know...
Understood. Get a cat? Seriously, I think you could put some glue traps around inside the engine bay that would at least catch any mice that do make their way inside. It would be ongoing rather than permanent, and you'd have to check them every day.Unless there's a trap that would be effective in the engine bay, I won't have much luck. The issue is I have to park the car outside in a rural area...
I bought some glue traps and I'll try to put them around the engine bay when they arrive tomorrow. It'll make me check the car more often too (working from home I am not a daily driver by any means...)Understood. Get a cat? Seriously, I think you could put some glue traps around inside the engine bay that would at least catch any mice that do make their way inside. It would be ongoing rather than permanent, and you'd have to check them every day.
I wouldn't waste your money on an ultrasonic device. From everything I've read they may work for a time, but rodents will eventually become accustomed to the noise rendering them ineffective.
Did you get OEM air filters? Were those cheaper than from Ford?I bought some glue traps and I'll try to put them around the engine bay when they arrive tomorrow. It'll make me check the car more often too (working from home I am not a daily driver by any means...)
The ultrasonic devices I've heard mixed feedback on. Some say it works great, others say they get used to it. They also have a strobe light, which apparently is very discouraging for rodents in small places, and they don't really get used to it. I figure the risk of hoping it helps for $20 is worthwhile to supplement the peppermint oil spray and the traps. In an ideal world, the other bits will deter them from wanting to be around my car, and the traps will be a just-in-case backup.
Edit: New cabin air filter in place (after sanitizing the area in which the filter fits...) and the relief is immediate. Also props for Ford creating a higher filtration standard with the Refresh95 filters, just wish they were more generally available other than online ordering...
I bought Motorcraft OEM air filters, and I made sure I bought the Refresh95 versions. Refresh95 is a newer air filter that Ford introduced in 2021, but may not be in the earliest Bronco Sports. Ford's bit on the Refresh95 filters here.Did you get OEM air filters? Were those cheaper than from Ford?
Along with suspension lift the spacers have added probably the best look to the vehicle. With aggressive tread tires it really changes the style and vibe of it. Love it.Nice. I did the 1" from Titan.
