Anyone install a plugin tuner on their BS?
Bloomsey
Nick
Fort Wayne
No interest.
seoden88
Scott
Louisville, KY
'22 Bronco Sport Badlands
pedal commanders are not tuners just FYI. All the do is increase signal to throttle body to make it open faster. Same thing can be done by pressing pedal harder. If you want a tune get a real tuner and have someone tune it for you. Plenty out there. Unleashed, Cobb, etc.
Bloomsey
Bloomsey
Nick
Fort Wayne
Got it! thanks for the info. didn’t really know anything about them so that’s why I’m asking
jkeaton
Greatest country on earth!
This one
I didn't believe those pedal commander devices would make any difference because, as stated., just push the go pedal harder. Well, I was gifted one and I tell you, what a difference those things make. It's different than "just press the gas pedal harder". The difference in throttle response is incredible. It makes the throttle much more responsive to inputs. Just pressing the pedal harder does not eliminate the lag. The pedal commander works by altering the signal between the accelerator pedal and the engine control unit (ECU), which affects the way the vehicle responds to inputs and virtually eliminates all lag. I have one on my Escape and my F150. I prefer this over a "tuner" as it in no way affects the factory tune or warranty.
Black Rob
South Carolina
This isn’t a pedal commander. A noise maker
I installed a plug-in system from Racechip USA. It's a German performance company. It doesn't overwrite your ECU. Can be removed easily if you need warranty work done.
You are going to get a ton of "bullshite", "they don't work", "they aren't like a dyno tune" and various other so-called expert opinions on any type of plug-in tuner/tune. In this day and age, we are way past having to have a dyno tune to improve performance by changing the parameters of engine output.
My advice is to research the companies you are interested in and educate yourself. Look up reviews. Look up claims against the company. Contact them and ask questions. A legit product will be open to Q&A, will back its product, and will have data out there proving the science behind what they do. That's why I went with Racechiip.
Cool and all, but the product he asked about does none of that. It plays engine sounds through the speakers.
I just Googled the Racechip tuner. I wonder why an auto manufacturer wouldn't use say this tuner when it's said to add more horsepower and up to 20% better MPGs. Especially when auto manufacturers struggle to keep up with CAFE regulations.
  • Up to 30% more HP and torque
    RaceChip performance optimization unlocks up to 30 % more power.
  • Up to 20% more MPGThe significant increase in torque enables earlier shifts which leads to less consumption.
jkeaton
This one
Yeah, I know. I was responding to the other person who brought it up. Went off topic there....lol
cprcubed
Parker, TX
Probably because their claims are BS. I'd want to see the dyno sheets backing those numbers up. You don't get something for nothing. Many times you need supporting mods (for example, larger injectors) to get those kinds of gains. Manufacturers also need to worry about emissions and reliability as well. Cheers!
Deleted member 12075
I just recently saw this ForzaTuner™ – OBD Digital Exhaust from Car Speakers - V2 Pocket Boost (forzatunerchip.com) on Tiktok, all it is is a plug-in that connects to bluetooth (I believe) and can change the engine rev sounds. Wanted to get yall's opinions on this, might be something fun to make your Sport a bit more loud.
Ford Bronco Sport Anyone install a plugin tuner on their BS? Captur
https://forzatunerchip.com/
I’d be careful with both plugins and tunes. Homeland Security just raided Cobb on behalf of the EPA for providing such. Call me a conspiracy theorist if you will but they now have records of every transaction (i.e. everyone that has purchased a component or tune)they had on record. You know, addresses emails and telephone numbers of their customers. I don’t think it’s a far stretch for them to start going after the end users, in Cali and NY especially. Prolly send in SWAT for you violent offenders of the atmosphere!???
kshaw
Kent
Gaithersburg, MD
Here is more on the Cobbs Tuning. I
Hedge36
Scott
Washington State
2024 Badlands
You know, I've seen some stupid accessories for all manner of vehicles, but... just wow. This is like the adaptor cable that drives a Harley speedo off the wheel of the trailer that carries it to Sturgis.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
I only trust COBB or SCT and a reputable tuner. COBB however just lost a 2.9 million dollar lawsuit against the epa and has to destroy all their inventory and will no longer offer support for their current tuners and software. So idk what will happen to them.
