Suggested FORSCAN changes
Sig Oris
Western Maine
2021 BSOB
Just joined the FORSCAN CLUB and looking for suggested changes or hidden features for our MY21 BS-OBX
Already did Bambi Mode and SOC to 90% and the splash screen.
While poking around I found a change to put the heated steering wheel control on the sync display so it’s because of this I’m asking if there’s other cool things to enable. It’s the wife’s vehicle and she likes the HSW mod so that’s why I’m asking if there are other features to enable.
Sig Oris
Western Maine
2021 BSOB
@Sig Oris .. what do you mean by Battery SOC (State of charge), can you provide the FORScan details for that?
yes, it’s State of Charge, there’s a dude on the Ranger 5g who’s been doing lots of battery testing and in his opinion 90% is an ideal setting. I’ll look to see where that setting is.
Kratz17
Washington
This is pretty cool. I got my adapter last night and I'm learning about it. I have the 2023 Outer Banks and I want to enable all this cool features. The Bambi Mode sounds cool. How do I enable that?? I'm still a newbie in this Forscan stuff but it does sounds awesome. Thank!
Devbloggs
2022 Bronco Sport Big Bend
i tried the auto high beam fade way back and it didnt work, unless forscan has changed something
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
What ForScan setting did you use for "Bambi Mode"?
its under high beams settings in body control module. you set it to unrestricted.
you can also set up auto high beam fade on and off, parking lights with drl, fog lights with DRL, disable hyperflash when you have led lamps in the rear brake and signal positions, change tire size, disable double honk, and other chimes, and maybe global windows up and down depending on your trim level. i think thats about all i ended up doing.
acomeaux33
Aaron
Louisiana
with the parking lights wit drl and fog lights with drl do the drl go off with your turn signal?
Kotkoj
Saskatchewan, Canada
2012 Bronco Sport
Changes I've made. Stopped headlight from turning off with signal light, turned off auto door locks, disabled drivers seat belt babysitter, extended the time 12v power port stays on to 6 hours, change battery state of charge to 90% and I removed the double honk if i leave vehicle while its running.
