Yesterday I installed a set of helper springs from Air Lift. We plan to do some off road camping, so we'll need to carry everything needed in the back of the Badlands. With everything we plan to carry loaded, the back end of the Badlands sits significantly lower. Every inch the suspension sags takes away from suspension travel and ground clearance. These helper springs are meant to do exactly what their name implies—they help the primary springs to prevent suspension sag. They are essentially rubber air bladders mounted inside the coil springs that are inflated through a Schrader valve. One important note: The User Guide says these air springs do not increase the vehicle's maximum GVWR as established by the manufacturer, so the sole purpose is to prevent sag.
This is the kit Air Lift recommends for the Bronco Sport:
https://www.airliftcompany.com/shop/60858/
If you decide to purchase online be sure to shop around. These kits are available at wildly different prices. Also make sure you include shipping costs. One of the sites I checked offered this kit at a significantly lower price than any other, but after you included the $30 shipping charge (for UPS ground!) it was around the same as other discount sites. I ended up getting mine from Michigan Truck Spring.
Installation took about two hours, including time spent going through the installation instructions and planning. The instructions are pretty clear, and I think anyone with average mechanical skills could install it without too much difficulty. The kit includes all the components you need to either tee the air lines to a single Schrader valve and inflate both airbags to the same pressure, or to install a separate Schrader valve for each airbag. I opted for the latter to account for uneven loading.
First things first; you have to jack up the back end so you can take the wheels off. You can jack up one side at a time, but I don't like working under a vehicle sitting on a jack. Instead, I jacked up the entire back end and placed a jack stand under the aft jacking points on each side. Be sure and chock the front wheels since you cannot use the parking brake.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_115929
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_115915
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_115903
Once you have the wheels off you can decide where to route the air lines. The airbag will sit inside the coil spring with the air line exiting a hole in the bottom of the spring mount. The instructions don't really tell you where to route the lines (there is a recommended location for the Schrader valve which I chose not to use), but it does include a warning to stay away from heat sources. My first idea was to run the lines to the back bumper and install the Schrader valves there. If you look underneath your car you'll see the exhaust system takes up almost all the room between the rear axle and the bumper. Routing the lines away from all the hot exhaust parts back there seemed like too much trouble. Additionally, the Schrader valves would have to mount in the plastic fascia covering the bumper, which is not a very sturdy option. I decided to use the brake line support tab welded to the frame in each wheel well. It's solidly mounted, and plenty big enough to drill the 5/16" hole required to mount the Schrader valve.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_140919
That decision made, air line routing became super simple. I ran the line through the hole in the bottom spring mount on the lower control arm, then internally through the lower control arm inboard to the pivot point, then up through the inboard hole on the lower control arm. The photo below was taken from behind the rear axle looking inboard on the driver's side. You can see the black air line going in the hole at the bottom of the spring mount, and out the hole near the pivot point.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_134834
From there, I went up into a hole in the upper control arm, then outboard back toward the spring before exiting through a slot on the upper control arm mount weldment. The pic below left was taken from in front of the control arms looking aft on the driver's side. You can see the air line entering through the spring mount on the lower control arm, coming out the inboard hole near the pivot point, then going up in the the upper control arm before exiting the slot at the top mount. Note the spiral wrap on the air line where it exits the upper control arm mount. You'll see in later pics I installed this everywhere the air line contacts an edge to prevent abrasion. This spiral wrap is not included with the kit. The pic below right is from behind the control arms looking inboard/forward; it's a better view of the air line routing between the control arms.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_151735
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_141625
The pic below left was taken from slightly above and behind the rear axle looking inboard and aft on the passenger side. You can see the air line exiting the slot in the upper control arm mount, which just happens to be right next to the brake line support tab. The pic below right is a better view of the air line secured to the brake line and connected to the Schrader valve in the brake line support tab.
NOTE: Be sure to slide the clamp on the air line before connecting it to the barbed fitting on the Schrader valve. If you forget you have to take the air line off the barbed fitting. Getting the air line off the barbed fitting is a royal PITA. Ask me how I know...
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_151703
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_151535
After routing the air line it's time to install the airbag inside the spring. To do this you must first deflate the bag, getting all the air out of it, then fold it into the shape of a hotdog bun. These bags are made of sturdy rubber, and they're not easy to squish and fold. I started by putting them in hot water for a few minutes to make them more pliable (not in the instructions, but seemed logical). Then I squeezed/folded/held them while my wife wrapped a couple of zip ties around them.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221030_152921
Once you've got it folded/spindled/mutilated (inside joke for the fellow veterans) you can push it through the spirals in the springs. Be sure to get the hose attachment at the bottom.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_141850
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_142001
Before you clip the zip ties and allow the airbag to inflate be sure it's high enough inside the spring that you can access the fitting. Slide one of the provided clamps onto the air line (first!), connect the air line to the fitting, and secure with the clamp.
NOTE: You may have to pump a bit of air into the bag to get it to inflate.
Once the bag is:
  • inside the spring
  • in it's proper shape
  • with the airline connected
You push it all the way down to the bottom of the spring so it just touches the bottom spring mount. It's a tight fit inside the spring, so I recommend having some soapy water on hand to provide a bit of lubrication.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_143802
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_162129
After that, you inflate the air bags to 30 psi and let sit overnight to test for leaks. Ours had no leaks, so they're good to go. The user guide requires you leave a minimum of 5 psi in the bags at all times. I drove the car with 5 psi in the bags and didn't notice any difference in the way the car rides/handles.
Let me know if you have any questions. End of post.
NOTE FOR ADMIN: I cannot delete the photo below using the site editor.
cario65
Chris
Northern Virginia
2023 Bronco Sport (ordered 8/11/22)
Excellent write up!
You will have to put a load on them and take pics. Pressurized and with just the min pressure to see before after
IdahoDirtFarmer
Shane
Caldwell, ID
Ram 1500 ordered '23 sport
When mine actually gets built that was going to be one of the first things I looked for. I added the Firestone coil bags to my Ram about 10 years ago and I've been incredibly happy with them.
Winds of Change
Chicagoland
Just like air shocks in the olden days lol.
xlite
Socal
Excellent how-to explanation. Thank you for taking the time. Looking forward to your review.
WildFord
Los Angeles
'22 BS BL
great stuff! something to consider in the future. Looking forward to your experience/review.
is there a way to epoxy the valves to the car frame/body in a good location?
I wonder if anybody has try using elastomers instead/in conjunction of air springs. Elastomers will provide some damping effects. High pressure on the air lifter may overcome the existing damper??? I don't know. Just a thought. inserting pieces of elastomers and fixing them in the coil spring probably won't be easy either
MaxVelocity
Montana
1970 Bronco
I don't know if it would work on the BS, but some people mount the valve(s) behind the fuel filler door.
I thought about other locations, but after looking carefully I felt keeping the air lines as short as possible and having a sturdy location to mount the valves to were my top priorities. Here's a photo of the valve for the right side looking past the tire. It's a lot easier to get to than it sounds. Take a look at yours; you might be surprised.
Ford Bronco Sport Installed Air Lift helper springs on Bronco Sport Badlands 20221031_162202
Wandering Pinto
Dave
I was wondering how the air bags are working? I am heading to Alaska in four weeks towing a camper and will have the back of my Bronco filled with stuff. I haven't had time to load it to see how it handles the load yet. I put air shocks on my Pinto and they make a world of difference, so I assume the air bags will too.
So far so good. The manual for the bags requires a minimum of 5 psi at all times (my guess is to keep moisture out of them), and a minimum monthly check. They have maintained 5 psi since installation, so no leaks for me.
My only complaint so far is that under certain conditions I get a squeak--think rubbing your fingers on the outside of an inflated balloon. It's likely the spring(s) moving in relation to the airbag making the noise. I only hear it a very slow speeds, and only when going over significant bumps. I've been meaning to up the pressure a bit to see if I can eliminate relative movement between the bags and the springs, but I just haven't gotten around to it yet.
Wandering Pinto
Dave
I ordered a set and started to put then in today. I am having trouble putting the bags in the springs. The way the instructions show you roll the air out and put them in basicly flattened out. That didn't work. I tried to fold them like you showed and cant get the top and bottom to bend like you showed. The top and the bottom fell thicker than the sides and I can't get them to bend that much.
Yes, it can be a struggle. I had my wife help me get them folded up; I folded them while she got the zip ties around the ends. You may need to apply a lubricant to the airbag/spring to facilitate going between the coils.
I assume you have the vehicle jacked up with the weight off the wheels. If not, there will not be enough room between the compressed coils to fit the bag.
Wandering Pinto
Dave
Yes the Wheels are hanging. Ill just keep at it. Thanks for replying quickly.
Wandering Pinto
Dave
What a pain is the a$$, but the bags are in! Just got to run the air lines and mount the valve.
