Rally Innovations Light Bar on a BL... Tool question if you have done them
LBinWNC
Lou
Western NC
MY23 BS
Hi Guys,
It has been a long time since I have done any work on cars (late 80s) which is one reason for the BSBL a retirement project.
I have the RI skid plate and light bar on order and wanted to make sure I could reach the bolts for the tow hooks without pulling the bumper.
I guess they are metric bolts ?? 1/2" box wrench is too big and 7/16" too small, I don't want to use an adjustable because they tend to strip things. And a ratchet doesn't have enough room.
For those that have done the install what did you use ??
Is the BSBL mostly metric or SAE ?
I may need some new tools...
Thanks
LBinWNC
Lou
Western NC
MY23 BS
Yes, flex ratchet set in metric on order….
Did you install ? PIA or ok ?
They are metric. Ratcheting wrenches are your friend.
Did you mean ratchet wrenches or a ratchet and sockets? Want to help the OP so he gets the correct tools and/or can determine if he wants to take on the project.
Robins21
Horse Pasture, Virginia
CallMeBill
2022 Carbonized Grey Badlands
I used a ratchet wrench and yes it is time consuming especially trying to put the bolts (1 each side) back in while holding the bracket and trying to tighten the bolt by hand til you can get the wrench back in. Just take your time. Def worth it
LBinWNC
Lou
Western NC
MY23 BS
I ordering a set like these
CRAFTSMAN Ratchet Set, 7-Pack, 72-Tooth, 180 Degree Flexi Head Design, Solid Chrome Finish (CMMT87009) https://a.co/d/eQgAiW8
JohnSilver
Knoxville
Yes I used ratchet wrenches and vice grip along with an adjustable work stool to hold one side up so I could get the other side bolted in.
Winds of Change
Chicagoland
It's an OK PIA. I have the light bar with two pod lights. I am considering removing it as it's a PIA to clean that area due to the tight fit. FYI.
LBinWNC
Lou
Western NC
MY23 BS
the wife will act as the holder…. What lights did you go with ?
LBinWNC
Lou
Western NC
MY23 BS
I can see that.. my BSBL is rarely pristine
JohnSilver
Knoxville
Lasfit 22in amber light bar. This was my 4th different light set up before I could look at it and say "that looks good"
Ford Bronco Sport Rally Innovations Light Bar on a BL... Tool question if you have done them PXL_20230728_162545857.PORTRAIT.ORIGINAL~3
LBinWNC
Lou
Western NC
MY23 BS
Yeah saw yours on FB which made me consider other lights than the Baja. I am really leaning towards this bar connected to a Trigger Controller for looks, growth and simplicity.
JohnSilver
Knoxville
Ah ok! Great. Yeah I will definitely be upgrading to the trigger eventually when I get more lights running.
CrazyKZ
Ken
Allen, TX
For me the Trigger had loud clicks, so I returned it. I went with the Auxbeam 6 gang and love it.
