Black exhaust tips.
Where did you get them and how about a rear pic?Black exhaust tips.
AmazonWhere did you get them and how about a rear pic?
I'm probably going to buy a set but I wish the tips were straight out instead of to the left and right. Unfortunately, the exhaust end is not straight down.
I put that insulator on but added the fender apron insulators too (M1PZ16E133A & M1PZ16E132A) that get wedged in the fender area above and forward of the wheels. While I was at it I installed the hood side weatherstripping which may help with hood shakes at higher speeds (M1PZ16A239A & M1PZ16A238A).My own thought is primarily cosmetic with not much sound deadening or heat blocking but I’m not a mechanical engineer so that’s purely a guess.
also, for whatever Ford’s reason was, it was not standard on all BS models but I no longer remember which model(s) have the dash panel insulator as standard from the factory.
@cario65 … would you be able to post a couple pics showing the fender apron insulators M1PZ16E133A & M1PZ16E132A (that get wedged in the fender area above and forward of the wheels) that you installed? I think those were installed at the factory on my ‘22 Badlands.I put that insulator on but added the fender apron insulators too (M1PZ16E133A & M1PZ16E132A) that get wedged in the fender area above and forward of the wheels. While I was at it I installed the hood side weatherstripping which may help with hood shakes at higher speeds (M1PZ16A239A & M1PZ16A238A).
I ordered a set and will try them both straight and to the left and right. They look like they will tilt down too much for a straight back look.I think you can adjust them to point straight down. I thought they looked good angled a bit. I didn't want them to seem to low to the ground. YMMV![]()
Looks fantastic! Thank you for giving us the opportunity to help set this up for you and for choosing Discount Tire!Actually yesterday ... new tires and wheels. Sparco Gravel wheels and KO2 245/65/17. I love them! Thank you @RodNSA for the wheel inspiration and @Discount Tire for being a first-rate company to do business with.
With the hood weatherstripping is Left and Right facing the engine bay or sitting in the vehicle? Just want to make sure.I put that insulator on but added the fender apron insulators too (M1PZ16E133A & M1PZ16E132A) that get wedged in the fender area above and forward of the wheels. While I was at it I installed the hood side weatherstripping which may help with hood shakes at higher speeds (M1PZ16A239A & M1PZ16A238A).
I would like to see pictures of the hood side weather stripping..I put that insulator on but added the fender apron insulators too (M1PZ16E133A & M1PZ16E132A) that get wedged in the fender area above and forward of the wheels. While I was at it I installed the hood side weatherstripping which may help with hood shakes at higher speeds (M1PZ16A239A & M1PZ16A238A).
Sitting in vehicle. These look the same to me thoughWith the hood weatherstripping is Left and Right facing the engine bay or sitting in the vehicle? Just want to make sure.
