Installed Tectico Plug’N’Play side marker lights today
Nosmo Rex
Beaverton, OR
2023 Bronco Sport Outer Banks
I installed these today and found it to be a fairly easy process (thanks to @Chiefthepup for the guidance). The trickiest part for me was accessing the existing marker lights to connect the harness. The instructions say to "remove the fixing screw" to pull out the light and remove the connector. There is clearly no "fixing screw". I was able to access the connector and remove it in place, thanks to skinny fingers. I bought some 1/4" wireloom from Amazon and pre-installed it on the wire, which I believe also aided in fishing the wire down to the side marker from the engine compartment. I also have some nifty needlenose pliers which were a great help in removing the existing trim plate and also removing the connector from the side markers. I also followed the advice to "pre-compress" the clips on the Tectico lights to make them snap into place a bit easier.
Ford Bronco Sport Installed Tectico Plug’N’Play side marker lights today IMG_20230715_105556
Ford Bronco Sport Installed Tectico Plug’N’Play side marker lights today IMG_20230715_095826
Chiefthepup
Chiefthepup
Colt
Washington
I’m 100% uninstalling and putting that same wire loom on mine. I don’t know why I didn’t think of that. The wires are definitely very frail feeling so good call! Stoked you got them put in!!
Nosmo Rex
Beaverton, OR
I'll post a pic tonight after it gets dark. I am also thankful that I installed this morning as it is now 97 degrees.
Do you have to uninstall if you used a pre-slit product like this?
ZhiYo 100 FT 1/4” Wire Loom Split Tubing Auto Wire Conduit Flexible Cover https://a.co/d/eyuNRbm
Nosmo Rex
Beaverton, OR
Chiefthepup
Chiefthepup
Colt
Washington
Nosmo Rex
Beaverton, OR
Tried to insert a video, but the site is not having it. Here's a somewhat blurry pic.
Ford Bronco Sport Installed Tectico Plug’N’Play side marker lights today IMG_20230715_212148
Chiefthepup
Chiefthepup
Colt
Washington
Well done!! That’s looks awesome idk what it is but I seriously am digging these side marker lights. Just seems so silly to have a pointless plastic piece so I’m stoked they put out a plug n play set up. 10/10 ?
