Is there a gauge either programmable and have show up in the instrument panel or an aftermarket gauge that will show the voltage and or the percent of charge the battery has?
These diagnostics likely won’t be all that useful to you for what you want (see NOTE for why)… provides battery voltage but not % charged.Is there a gauge either programmable and have show up in the instrument panel or an aftermarket gauge that will show the voltage and or the percent of charge the battery has?
Here is an aftermarket gauge.Is there a gauge either programmable and have show up in the instrument panel or an aftermarket gauge that will show the voltage and or the percent of charge the battery has?
I had the same issue. It seems outside temperature plays into the functionality even if your heat or AC is off. I noticed it not activating when the temp dropped below 60. Above that it seems to work fine. Personally I like the feature. It saves fuel, I understand old habits are hard to break. It took me over a month to get used to it, now I expect it to activate at every stop. Disappointing when it doesn't activate.My assumption is that one or more of the conditions is not met and is not activating like normal.
I would assume as the season turns colder and colder into winter for me, my Auto Start Stop will not turn on as much depending on temps.
Another option is a power adapter with voltage readout.Here is an aftermarket gauge.
A fully charged lead-acid battery should indicate around 12.5 VDC. A sealed AGM or Gel battery should indicate around 12.8 VDC. I think your dealership gave you another lead-acid battery from the same bad batch that went to the production line.Within minutes after I shut it off, the voltage drops to 11.9-12.1.
I agree 1000%. Four visits during which I got every excuse they could make up, and even after I contacted Corporate Customer Support, they still "couldn't" replace the battery because it checked out on the first stage (whatever that is). It was only luck that a specialist had been brought in to work on a different issue and told the mechanic to run the second stage test, that they agreed that the battery was failing, and they could replace it.A fully charged lead-acid battery should indicate around 12.5 VDC. A sealed AGM or Gel battery should indicate around 12.8 VDC. I think your dealership gave you another lead-acid battery from the same bad batch that went to the production line.
The recall isn't to repair anything; it's prophylactic in case you experience a fuel leak such as a cracked fuel injector. The software mod and drain tube should've been part of the original design, because a fuel leak is always a possibility, no matter how remote, and the basic engine design should include a means to shunt raw fuel and fumes away from the engine compartment.I'm seriously thinking about getting rid of it when they declare the drain tube band-aid fix for the cracked fuel injector - repaired.
When the dealer replaced my battery they installed a Motorcraft AGM battery, it's been 5 months and everything works as it should.After four visits to my local Ford service center, a highly trained expert who had been called in on another issue told the mechanic working on my BSOB to run the second level battery test.
At that point they finally decided that the battery was failing.
Unfortunately that is not the end of the story.
They replaced the battery with another FORD battery from their parts department.
It worked great for a month. The start/stop even worked when the temperature outside was 22F (-5.5C). Then it quit working again. And now spring weather has returned and it still doesn't work on a 50F day.
NOTE: I did buy a voltage monitor, and I can see that the battery is charging at 14.8 when I'm driving, dropping slightly to 14.6 when stopped for a red light. Within minutes after I shut it off, the voltage drops to 11.9-12.1.
I'm not going to even waste another minute with Ford Service.
I'm going to buy a battery from a reputable seller, and hope that solves the problem.
