Dark spot in headlight, dirty back end after driving in snow.
Repool
Ontario, Canada
ford fusion '08
Anyone notice this? There's a dark spot on drivers side headlight, about the size of a big dog about 45 degrees from centre of car. Is that normal? I'll take pictures when I get a passenger.
I have a clean car after driving 15 min in snow, except my whole back end had an inch of buildup of snow. It covered the whole back end, including headlights.
ps. just realized I said headlights, meant signal lights lol sorry for confusing people. Anyone have a way to reduce this?
jazzdab
Thom
Raleigh, NC
Have not noticed a dark spot. The liftgate gets dirty in al conditions. It's a downside of having a flat rear end with a short overhang from back axle.
Not trying to minimize your experience, but after coming from a small hatchback, the BS hatch area stays pretty clean. I haven't driven in deep snow, just plowed streets/roads. I won't pretend that it is clean, but it is much cleaner than my hatchback's would have been.
Sorry, no input on the headlight issue. Makes me wonder if there is something inside the headlight on the reflector or something?
RS1
Ralph
Boston
Linkie no workie?
cprcubed
Parker, TX
Link worked fine for me (???). Below is the text.
SSM 49645: 2021 Bronco Sport Headlamp Dark Spots Pattern
All 2021 Bronco Sport vehicles have headlamp low beam pattern with a dark spot dip near the horizon in the left portion of the beam pattern. These dark spots are most noticeable when the high beam is active. Although this dark spot is present by design, this issue may be more perceivable to the customer if the headlamps are aimed too low (dark spot will appear closer to vehicle). The vertical aim should be checked and adjusted upwards if necessary, refer to Workshop Manual (WSM) Section 417-01.
Vehicles:
2021 Bronco Sport (CX430) (HD)2021 Mustang Mach-E (CX727N) (GW)2020-2021 Explorer (U625N) (TW
Cheers!
Snake Eyes
Western PA
Bronco Sport Badlands 2023 Atlas blue
Ok so I guess I’m glad this is normal. I noticed it the first night I drove my BS. Still annoying but I guess now I know... and knowing is half the battle!
Weston52
Weston
Atlanta
04 Solara, 91 Miata
Repool
Repool
Ontario, Canada
ford fusion '08
ok so maybe I should talk to them. Thanks. It's just below the post on drivers (left) side of road. Just below pole.
Ford Bronco Sport Dark spot in headlight, dirty back end after driving in snow. PXL_20230310_042835128
That could be "normal". Generally the driver's side headlight is different to cut down on glare for oncoming traffic. If you buy headlights on a car that is also sold in England or Japan, there will be different light patterns for those countries (right hand drive). It appears in your picture that the dark spot aligns with the center of the road. That's what makes me think this could be intentional.
Mrmike
Syracuse, New York 13219
It's normal. If you pull my '23 OBX up close to my closed white garage door, You can see the same dark spot on both lights. It's the way their made. Adjusting lights may move it around, but it's always going to be there.
mdwheaton
Matthew
TLDR;
It's supposed to be there, so as not to blind oncoming drivers.
I have the spots as well. Was odd at first. Now, just spots!
Lane
Lane
Liberty, NC
2021 Ford Bronco Sport, 1999 F350
Yes. I’ve noticed it in mine as well.
Repool
Repool
Ontario, Canada
ford fusion '08
My dealership looked at it, now not as pronounced and doesn't draw the eye to it. Although still there, but can live with it. Thanks, just didn't want a deer being in such a dark spot. BTW almost hit 2 deer on my passenger side last night. They stayed on the gravel and I drove by them.
