- First Name
- Robert
- Joined
- Mar 23, 2021
- Threads
- 2
- Messages
- 1,321
- Reaction score
- 1,890
- Location
- California
- Vehicle(s)
- Bronco Sport
My guess is yours may already have the recall done then. I am wondering if they are installing that drain hose on all the new 1.5L engines to as they would still need a way to drain fuel away from the heat sources even if a new-style injector is used.Not sure about that as my 22 BB has not been recalled for this issue (yet). Built 10/22. I keep checking anyway. Cheers!
Can you share a source on this? I was not aware that Ford had "redesigned" the fuel injectors for newer MY Bronco Sports....the 2023ās are supposed to be built with the redesigned fuel injectors.
https://www.motor1.com/news/623668/ford-escape-bronco-sport-recall/amp/Can you share a source on this? I was not aware that Ford had "redesigned" the fuel injectors for newer MY Bronco Sports.
Respectfully, although the writer seems to imply the fuel injectors are defective, the recall document itself refers to a design defect, not a faulty component. According to that document, the root cause is still under investigation. Specifically:https://www.motor1.com/news/623668/ford-escape-bronco-sport-recall/amp/
āThis defective design was introduced into production on November 19, 2018 (the earliest production date for the 2020 Escape) and was taken out of production on October 17, 2022 (the latest production date for the 2023 Escape and Bronco Sport). The Ford Escape and Bronco Sport units that fall under these production dates are part of the said voluntary recall.ā
This is describing what can happen if a fuel injector cracks and leaks fuel into the engine compartment, not that the fuel injectors are faulty and WILL crack. The investigation may yet reveal that the fuel injectors are faulty, but my guess is that will not turn out to be the case.Based on analysis to date, a cracked fuel injector in the engine allows for fuel to leak at a high rate (19L/ hour) into the cylinder head, which can travel out via a drain hole and down onto hot surfaces on the exhaust/turbo system where it may combust.
I believe there are cases of cracked fuel injectors but is a small percentage. Ford would know they pulled the injectors.Respectfully, although the writer seems to imply the fuel injectors are defective, the recall document itself refers to a design defect, not a faulty component. According to that document, the root cause is still under investigation. Specifically:
The biggest clue is the proposed fix, which is to ensure any spilled fuel is routed away from heat sources. IMHO, this is at its root a design flaw regarding the engine's fluid drains (all engines have them). I believe if it were really an issue with faulty injectors the NHTSA would not allow Ford to begin recall work simply rerouting fluid drains. And since these injectors are almost certainly used in a variety of vehicles from different manufacturers, I believe we would be hearing about problems with other cars as well.
Right, because reducing engine power will reduce the amount of fuel flowing to the engine in the event of a fuel leak. This, along with routing spilled combustible fluids away from heat sources, is meant to reduce the likelihood of a fire should an injector crack and spill fuel into the engine compartment. This is a design change, not a component change. When you design something as complicated as an engine for consumer use you must account for failures. There is a possibility that any component under the hood could fail, and it is incumbent on Ford to ensure any failures will not result in undue risk to the vehicle's occupants.This is also documented in the recall:
āIf a pressure drop in the fuel rail is detected, engine power will automatically be reduced to minimize any riskā.
It remains that some injectors have been analyzed and found to be cracked. My guess is the fuel injector supplier is working on a design change and probably Ford is looking for another fuel injector supplier but that is my guess. Itās a low failure rate so cost is also a consideration. No deaths have been attributed to the recall as far as I know but time will tell what the end result of all tbisRight, because reducing engine power will reduce the amount of fuel flowing to the engine in the event of a fuel leak.
As I've said, it's possible the Ford in conjunction with the NHTSA may determine there's a problem with the injectors requiring fleet-wide replacement. Just based on the data, however, I doubt it.It remains that some injectors have been analyzed and found to be cracked. My guess is the fuel injector supplier is working on a design change and probably Ford is looking for another fuel injector supplier but that is my guess. Itās a low failure rate so cost is also a consideration. No deaths have been attributed to the recall as far as I know but time will tell what the end result of all tbis
Yep and thatās why I provided the link to the known data (there are other sources of data as well) for people to educate themselves to make their own decisions in conjunction with Ford and NHTSA published material.As I've said, it's possible the Ford in conjunction with the NHTSA may determine there's a problem with the injectors requiring fleet-wide replacement. Just based on the data, however, I doubt it.
someone bove says there have been fires from it though and i dont wanna risk that. smells like very strong gas fumes from engineGo to the Dealer and take back your BS. and Drive it till the parts come in. No harm no foul
There is a recall in effect due to the possibility of under-hood fire resulting from a cracked injector. One of the symptoms technicians are told to look for to diagnose a cracked injector is the smell of fuel. I would not drive your vehicle unless your dealership service department says it's okay to do so.someone bove says there have been fires from it though and i dont wanna risk that. smells like very strong gas fumes from engine
