Bronco script emblem installed
sinbuster007
Brian
Hagerstown, MD
2 SUV's, 2 Mustangs
any of these with "sport" added??
BodieBronco
Houston
Bronco Sport 2023
I'm about to have a day over 70 degrees with no rain, and I hope to apply my script.
Please help
Is there a template for the bronco sport? I found one for the bigger broncos.
What part of the fender area do I level from? I think I want to put it at the same height as the door handles.
Is there a way to do a wet application with these so I can slide it around to make sure it's perfect before committing?
Please help
Take a look , this might help .Buy 1 inch blue tape and match it to the hood joint and then 1 inch from the vent . That’s what I did if you like that look . Good luck .
Ford Bronco Sport Bronco script emblem installed 5936E78C-927E-4470-AFDC-783ADECA4D06
Ford Bronco Sport Bronco script emblem installed 791EFF72-1F0A-47E3-9D25-06ABEC8B9F74
Ford Bronco Sport Bronco script emblem installed 3ED3F141-7CBB-45E3-8669-729745DCFB42
Ford Bronco Sport Bronco script emblem installed 223CC6C3-CC37-43BD-B07C-352F0CD68BBC
BodieBronco
Houston
Bronco Sport 2023
Yes. Exactly the positioning I'm aiming for. Trying to figure out how to measure and level and mark off so I get it right
Please help
Please send pictures when done ,thank you .
You might be able to temporarily hold it in place using some high strength magnets just to get an idea. Then place your tape below and mark the start and end spots. I’m assuming the badges are plastic and not heavy.
