Fordone Badlands
Ontario
22 Bronco Sport
Installing OEM mud flaps today.
Ford Bronco Sport What did you do TO your Bronco Sport today? Resized_20230216_093743
Funny. I just picked up my front and rear splash guards today also. Also picked up the OEM Hood Deflector but need a warm day to install that.
CrazyKZ
Ken
Allen, TX
Do either of you have wheel flares installed? I'm pretty sure that the EOM ones for the rear will fit, but not sure about the fronts.
Jasonj7858
Jason
NC
21 Bronco Sport Big Bend..22 Bronco Sport Badlands
The front will fit but have to be trimmed if you have the fender flares...easier if flares are mounted first...rear ones are no issue with flares.
CrazyKZ
Ken
Allen, TX
Good to know! Yes, flares are already installed. Spacers are going on tomorrow, so I'll need something to keep the dirt off the car once the tires aren't "hidden."
Bro_Spo
Jake
Upstate New York
'22 Bronco Sport | '14 Fusion | '63 Galaxie 500
OEM cargo mat install. Clear instructions, no issues.
Ford Bronco Sport What did you do TO your Bronco Sport today? cargomat
Suzysparks
Stacy
Acura MDX Type S
Step 1 - take off plastic
Step 2 - lay on cargo floor
Step 3 - congratulations, you are done!!!
Step 4 - wait, recycle the plastic. ?
Fordone Badlands
Ontario
22 Bronco Sport
Had the garage warmed up, so after putting on the mud flaps, did the bug deflector install.
This was OEM and made by Lund. Uses 3m super tape all around to hold it.
Job came out 95% perfect.
Tip:
Have a second person to help hold it in place.
Secure the ends of the tape "liner" in place on the top side using a tape. There are many ends that need to be pulled out as it goes down and the ends tend to go back under on their own. That makes a problem trying to get the end back out since the unit is now somewhat secured.
ps: I don't know how you would ever get this tape to let go. It seems permanent now.
cario65
Chris
Northern Virginia
2023 Bronco Sport (ordered 8/11/22)
No major mechanical modifications, just connivence items.
1. Added an integrated pivot ball for a phone mount from Course Motorsport (install thread).
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4739
2. Fresh set of Drop Stop between two front seats. Used these for nearly 9 years on my Explorer and saved many of items going down between seat and console.
3. Cabinet door hook over side of console storage (I have a black metal one coming to replace the white plastic version). Why? Wifes idea, to hold her purse strap and keeps it in place at her feet. This hook is for a cabinet, not a room door hook.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_4759
4. Cargo tray linear installed in back.
5. Will be installing rear bumper protector when I get a chance.
6. Ford roof rack cross bars
7. Purchased the side vent turn signals from Tectico. But the design of it (plastic part) is not the quite the same as the original part regarding the smooth gray portion. I got the carbonized gray roof and it looks similar to that color. So still deciding if I want to keep that little bit of original detail.
8. Storage tray that sits behind the infotainment screen on the dashboard.
ErikaFrzn
Erika
‘22 Bronco Sport, '15 Explorer, ‘22 Trail Boss
Used my points to get the cargo cover and bumper protector, also got the rubber seat-backs.
Now I just need to figure out how to get the bumpers and bottom plastic pieces back to looking new(ish). Is a basic trim restorer the best for that?
Ford Bronco Sport What did you do TO your Bronco Sport today? 9792C081-6E2E-401B-9276-215917E4B479
Ford Bronco Sport What did you do TO your Bronco Sport today? 44290606-45F9-4E15-95E5-16F2C9525C3D
Ford Bronco Sport What did you do TO your Bronco Sport today? 0D97518D-48E7-4C2D-BCBC-EACB97D48967
CeraKote trim coating will make it all look new again.
C&C&C=The 3 Amigos !
Christine(Chris
Indiana
Bronco Sport BL
:clap: This past week all of the stuff has been done :rockon: I will take delivery on 2-20-23 :thumbsup: The new wheels & tires will be installed on 2-21-23. :like: So far The Ceramic Coating was done :handsinair: The Front two window where tinted to match the factory tint :sunglasses: BRONCO SPORT 2021-2023 AEROSKIN II TEXTURED HOOD DEFLECTOR :sunglasses: BRONCO SPORT 2021-2023 REAR BUMPER PROTECTOR :sunglasses: BRONCO SPORT 2021-2023 CARGO AREA LINER FOR SPARE TIRE :sunglasses: BRONCO SPORT 2021-2023 FLOOR LINERS 4PC SET FOR RUBBER FLOORING :sunglasses:
:crazy: Oh my :rolleyes: I wish Ford would of had a upgrade or the option of ordering with
the black wheels for the BS/BL :D
Ford Bronco Sport What did you do TO your Bronco Sport today? tempImageIoAeQu
:crazy:Oh my :rolleyes: I wish Ford would of had a upgrade or the option of ordering with
Actually you can buy the rims by ford in black that comes on the First Edition ford ..
Ford Bronco Sport What did you do TO your Bronco Sport today? 7A448DFF-2B48-4083-B1F8-CB7E20D037EB
Ford Bronco Sport What did you do TO your Bronco Sport today? A2AC0CF5-0690-48EF-B57C-25F4557DF749
Ford Bronco Sport What did you do TO your Bronco Sport today? 7B0720C7-DB28-43DB-AFB2-D9458DC547C0
