A
A local shop is offering me a 1.5 inch lift and 1.5 inches spacer
I don’t think you want a 1.5” spacer. I would recommend 25mm (1”) as a maximum spacer with a 245 wide tire and a wheel with 38mm offset (stock offset). My wheels have a 30mm offset and I think that extra 8mm is what makes my tires rub.
Lufelham
Luis
Mexico
Bronco Sport Badlands 2022
got the 245/65/17 tires and RC 1 inch lift im still thinking about the spacer
RogueRodney
Rodney
McKinney, TX
Can you get a picture of your front quarter panel/tire, would like to see how it looks.
Thanks,
RR
CrazyKZ
Ken
Allen, TX
Track Width
I really wanted to have a more aggressive stance. I didn’t want the tires to stick out but I don’t like the “fake bolt” fender flares. Luckily Air Design has nice clean fender flare set. This flare set looks very “stock”, which I like.
The 245 tire on a 30mm offset wheel sticks out just a little. When a 1” spacer is added, the tire really sticks out. Maybe something that some others would like. Adding the fender flares, brings it back to about flush. To me, this is perfect.
The decrease in wheel offset from 38mm to 30mm moves the outside surface of the tire out by 8mm (about 5/16”).
The increase in tire width from 225mm to 245mm means another 10mm (about 3/8”) of the tire pushing out, and also the same amount pushing in.
Stock
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667438311049
245/70/16 30mm offset (stock offset is 38mm)
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667438365391
245/70/16 30mm offset with 1” spacer
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667438402215
245/70/16 30mm offset with 1” spacer and Air Design fender flares
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667438450146
Apparently it looks like I'll end up needing a spacer too even with the 245's and the same rim. Was that a huge deal to put in a spacer? Where did you get yours from?
Any change in performance or turn radius with the spacer?
Spacers from Amazon:
https://www.amazon.com/dp/B01BEI7SG0?ref=ppx_pop_mob_ap_share
I would recommend a 20mm spacer instead of 25. A little rub on mine.
You just need someone to hold the brakes as you tighten them, otherwise they are a simple install.
I didn’t really drive it before putting on the spacers, other than the drive home. I don’t think there’s any change in performance or turning radius.
I do think that the 245’s are too wide for snow or the Toyos are just shit in snow. Good grip but horrible tracking.
CrazyKZ
Ken
Allen, TX
Did you end up putting on spacers? I have some 1" spacers on order, but I can't decide which way to go.
Lufelham
Luis
Mexico
just had time to install the 1.5 spacer lift from RC didn't buy the spacers and i have yet to install my tires the TOYO ATIII 245/65/17 ill install them on saturday
Ford Bronco Sport Olive - Meanderthal’s BS BL IMG_3772
Ford Bronco Sport Olive - Meanderthal’s BS BL IMG_3766
RogueRodney
Rodney
McKinney, TX
Looks good Lufelham, did you notice a drive difference?
RR
Lufelham
Luis
Mexico
RR
Feels really similar since it’s the stock suspension but you definitely fell more the cornes at speed also the height it’s really noticeable but fells good my suspension is new if this truck lasts me long enough and I damage the suspension I’ll get a GR40 from flat out in the future I’ll send you pictures tomorrow with the new wheels
Lufelham
Luis
Mexico
RC lift + TOYO ATIII 245/66/R17
Ford Bronco Sport Olive - Meanderthal’s BS BL IMG_3849
Ford Bronco Sport Olive - Meanderthal’s BS BL IMG_3846
RogueRodney
Rodney
McKinney, TX
Lufelham:
Looking good my friend! Meaning no slight at all to anyone that doesn't have a lifted Bronco Sport, but I think they look so much better (more boxy/blocky) lifted.
I liked it without the lift, but it looks much better (in my opinion) lifted.
RR
Winds of Change
Chicagoland
DX4 X-Trail
https://www.dx4wheels.com/copy-of-x-trail
Discount Tire: https://www.discounttire.com/buy-wheels/dx4-x-trail
Not listed as a fit match for the Bronco Sport but it does. Offset is potentially the issue for the 16” size but the 17” size has a 38mm offset. I think this is an oversight and I just happened to find it by snooping. This is a nice low cost option ($190/ea).
I chose the 16” size in order to get the taller sidewall. More sidewall is good for rocky trails and I live in “The Rockies”. The rule of thumb is the tire diameter should be double the wheel diameter. Not quite there with the 245/70/16 but it is a little closer.
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667436627326
Tire is Toyo Open Country A/T 245/70/16
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667436763217
It appears that there is potential to run a 15” wheel with a 75 series tire. It is hard to get anything in there to take a measurement but I can easily fit my fingers between the brake caliper and the wheel barrel.
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667436804878
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667436858456
Just to add a little bling and to get rid of the dreaded 2-piece Ford lug nuts, I went with these colorful lug nuts.
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667436898467
RYANSTAR 20Pcs M12x1.5 Wheel Lug Nuts, Closed End 6 Spline Nut, Bulge Acorn Cone Seat Wheel Locking Nuts, with 19 Hex and 21 Hex Security Key Multi-Color
Interesting that the weight of this combination is not much different than the stock setup.
Here is the new wheel/tire combo:
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667437010198
Here is the stock spare tire with steel wheel:
Ford Bronco Sport Olive - Meanderthal’s BS BL 1667437045768
I couldn’t get a picture while trying to hold the stock wheel and tire, which a now separated to harvest the sensors for the new wheels/tires. Those came in at just over 51 lbs. So, just a couple of pounds difference between the setups, which is less than the difference between one tire/brand and another in general. That is with a 245 tire instead of a 225.
Am I to understand I can look for other wheel styles with a spec of 16x7 with a 38mm offset or 30mm offset?
I don't know if you understand it but a 16X7 wheel will fit and even possibly a 15X7. The stock offset is 38mm but the wheels I bought have a 30mm offset and I also put a 25mm spacer, effectively making the offset 5mm. I don't think you will find many wheels with an offset less than 30mm but they are out there. You could also consider wheels at least 8 in wide. I'm pretty sure others here have used an 8" wide wheel.
Winds of Change
Chicagoland
It is always the offset that throws me off. But this helped clear it up, in essence I start with a large positive offset and the more offset added gets me closer to 0 and will stick out farther correct. So any offset from 38mm on down would work?
