Steel 16” wheels!
Maxwellian
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Very happy with the setup so far. We explored the Panamint valley south of Ballarat. Found the limits on clearance, had to stack rocks in one spot, but grip was great on the loose rocky bits. Didn’t take enough pictures, but here’s some wild burros.
Ford Bronco Sport Steel 16” wheels! D165FC97-1353-4432-9E1B-DC36A6DB6182
Maxwellian
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
So I got 6mm wheel spacers to get the offset back to stock. I only had 6-7 threads engaged, which seems like about maximum strength of a threaded connection to me, but I got extended thread lug nuts just in case. Everyone says 9 turns on 12x1.5 minimum. I also added some vinyl caps to keep crud out of the hubs. There wasn’t anything for a regular center cap to clip to.
Ford Bronco Sport Steel 16” wheels! 31DDD81F-4DDF-45D8-A60C-350FE676DD28
Ford Bronco Sport Steel 16” wheels! B2DB9917-F92A-4CE2-A83E-A37426EB9D32
Vinyl caps: https://www.mcmaster.com/#9753K22
Lug nuts are Gorilla 41137ET
xlite
Socal
Nice I have seen just 2 other bs in the valley
I really like that look with those rims.
Did you put the same for your spare?
And did it fit inside?
I’m another valley sport. Have only seen a couple near me.
Maxwellian
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
I need to get rid of my factory spare. I’m pretty sure I test fit these in these in the spare well, but maybe I should double check
Maxwellian
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Finally got around to double checking the fit. Fits, lifts up the load floor by maybe an 1/8”.
H.M.
Earth
Bronco spot first edition
Where did you get the wheel spacers?
Maxwellian
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Oh, I guess they were 5mm from Amazon.
https://a.co/d/2Bb2fND
Wheels are bolt centric, so probably could have used cheaper universal ones. Any 5x108 spacer with >63.4mm bore would work.
The aspect ratio is important off road. The more rubber between you and the rocks, the smoother the ride. The trend to low aspect is great for race cars, and gas mileage but terrible for the rough ride. My wife's Hundai has low aspect ratio tires and rides rougher than my Jeep Liberty with KO2s. If you're a towny, the 18" wheels will work fine.
