Trip 2 screen?
rmreid22
Bob
Western TN
'22 OB and yes I've read the manual (page 106) but I can't for the life of me figure out how to get to Trip 2 ? From the steering wheel controls or the menus on the radio screen - What am I doing wrong?
dakman
steering wheel controls- switch center display to trip/milage display- hit menu- use center button to toggle up or down to desired page push center button in to enter, hope helps
rmreid22
rmreid22
Bob
Western TN
Did that or at least I thought I did, but then realized I am a dumb a$$ sometimes, all is good now :giggle:
Tigger
Tigger
Illinois
I’m glad you figured it out but I have a warning. Trip 1 and 2 are not clearly differentiated in the display.
So, if you are like me and you use trip 1 for each tank but you use trip 2 for something else, be careful and make sure you are resetting the right one after you fill the tank.
tRex
Rochester, NY
I preferred my old VW trip odometers -- one automatically tracked and reset itself after shorter trips, the other was ongoing until manually reset. I never remember to manually manage it for short trips where I might have liked to know "how far, how long did that take?" I would normally also use Trip 2 for manual MPG calculations per tank, or for longer trips.
Since you all have read the manual, and I haven't, what does the fuel economy screen tell me? It has an average mileage, but does it ever reset?
You choose when to reset it and you do it manually. The on screen display will prompt you to reset if desired when you toggle the display to land on the fuel economy screen.
425mb
Minnesota
24 Badlands
Just thought I’d share, on my 24 badlands I had to do a capacitor discharge, remove both terminals off the battery so there is no current through the battery and jump the terminals with a metal object again not letting them touch the battery and then holding for 30 seconds to allow all modules shut down. Reconnect the terminals to the battery and then when you restart the car you can choose more screens.
