LazyDirtFarmer
LazyDirtFarmer
Chicagoland, NE Illinois
LazyDirtFarmer
LazyDirtFarmer
Just “hasty” ones. I should put some in there. Any good sources?
I live in Chicago, and I am a CCL holder. So the possibility of a gunshot wound requiring a Chest Seal is a real possibility. I carry Hyfin Vented Chest Seals in my IFAK and EDC. The NAR brand is quality stuff.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
- One forty-five caliber automatic
- Two boxes of ammunition
- Four days' concentrated emergency rations
- One drug issue containing antibiotics, morphine,
vitamin pills, pep pills, sleeping pills, tranquilizer pills
- One miniature combination Russian phrase book and Bible
- One hundred dollars in rubles
- One hundred dollars in gold
- Nine packs of chewing gum
- One issue of prophylactics
- Three lipsticks
- Three pair of nylon stockings.
Fella could have a pretty good time in Vegas with all that stuff...
When I worked for the Forest Service, one of our trucks burned up because road flares were stored in a utility bed compartment directly above the exhaust. It got hot enough to light the flares. So use caution about where you store them.
I popped out the foam and put as much emergency stuff as I could fit. Axe, shovel, small pulaski (better than shovel when stuck), hand chain saw, jumper cables, recovery strap, rain jacket, gloves, first aid kit, wool cap.
Large washers will come in handy when you rip off the carpet "skid plate" on the driver's side, as I did on my first off-road excursion.
Major Kong
Major
Right now I’m carrying:
- Three lipsticks
It’s a tight fit but a fella can’t be too prepared.
? tip of the hat Econoline
"Shoot, a fella' could have a pretty good weekend in Vegas with all that stuff." - Major T. J. "King" Kong
Ford Bronco Sport Junk In Your Trunk - What's Under Your Cargo Mat? 1665610163866
Major Kong
Major
same cautionary warning for roadside use
place a safe distance from vehicle(s)
crash scene fuel leaks could become problematic
Or you could just get the LED flares.
Major Kong
Major
Very true
I carry both
however I've found other uses than intended for road flares
which is why I keep them along for the ride
in the past during deep subzero freezes
develop a need for a torch to heat materials
no torch handy
aaahhhhaaaa moment
road flare torch
in a pinch it works great
little messy spitting and sputtering
but if you are in need of a really hot flame this is it
jason202
Jason
Washington, DC
2023 Bronco Sport Badlands, 2009 Volvo C30 T5
I am trying to take advantage of the storage space in the spare tire area. The Fanttik T8 Jump Starter and X8 Tire Inflator fit perfectly in the foam tray. I got a 1/2" torque wrench and a non-mar lug socket; They fit the foam cutouts nicely too. And, I keep a tow strap, soft shackles, axles straps, and a trailer hitch shackle in there; I don't off-road (on-purpose :oops:), but winter snow is bad here; Folks get stuck all the time... In the cracks and crevices, I stuffed things like tie-down straps. rags, gloves, 50' of paracord, and a spare antenna and connectors for the GMRS.
I'm curious what other folks use this space for, and what I might be missing in my kit.
Ford Bronco Sport Junk In Your Trunk - What's Under Your Cargo Mat? 20221007_164528
Are you pretty happy with that X8 tire inflator? To me, having such a thing is essential and it's good to know this model fits next to the spare.
LazyDirtFarmer
LazyDirtFarmer
I've only used it on motorcycle tires so far... Took them from 0 to 30 much quicker than my old B&D compressor/starter combo. I did top off my tires... for that it works super! Preset to 33 and it stops by itself. In the winter here, the temp drops quickly and topping off the tires on a cold morning is a common need... now I can sit inside and not have to watch the pressure gauge :like:
jason202
Jason
Washington, DC
Oh yeah, that seems to happen to me just about every year when the temps cool down.
Winds of Change
Chicagoland
I sit inside and wait for discount tire to add air lmao.
