Red_405
Sonny
Okie
Loaner
? changed the Blue oval to Black!
Removed the OB sticky.
Added the sweet Black Bronco emblem.
& convinced my hubby to wire the side markers in!
Windows are getting tinted this wkend, she sure is coming together!
Ford Bronco Sport What did you do TO your Bronco Sport today? FBCD1151-22E4-4639-ACEB-9ECF872C3C17
Ford Bronco Sport What did you do TO your Bronco Sport today? 83C61C42-E8E0-40BE-9391-BC08F2D364F7
Very nice , great taste. Looking good .
Ford Bronco Sport What did you do TO your Bronco Sport today? 6AC06C8D-FFB6-40F0-9F85-4E0FCF5350AA
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Today, I went to Silverdale and while I didn’t do anything to my Sport, I did follow this F250 towing a Jeep up the highway. It just struck me as funny. For those that will say pics or it didn’t happen, here you go.
Ford Bronco Sport What did you do TO your Bronco Sport today? 6FE3A647-29C0-4B71-871D-2C0320BA2190
Ford Bronco Sport What did you do TO your Bronco Sport today? BFA70337-7B28-4C06-8273-784EF3FA095C
Wolf256
Jane
Kingston, WA
I really like those marker lights. Is the white wired to the headlights/DRL’s? Could you ask hubby if they were difficult and how long it took?
Red_405
Sonny
Okie
Loaner
Horse n Buggy
Stoge
Florida, USA
Is that the bolt on one and was it difficult?
It was not terribly difficult, my wife helped install it and it only took about 10 minutes.
You remove 6 of the plastic push pins that hold the hood seal in place. Then, at those locations, the Deflectors mounting tabs slide between the seal and the hood where it is secured with provided self taping screws into the holes that were you previously removed the plastic push pins from.
Most confusing part was which direction you spin the two rubber topped hood stops so it will close properly.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
finally sprung for a full size spare
conundrum
mini spare
discarding to trash just doesn't sit well
curbside metal scavengers may be best bet
any suggestions
I got my Flatout GR+ coilovers installed to day but didn't have time to set the final ride height or install the toe arm extension. Currently sitting at ~1.25" up.
Ford Bronco Sport What did you do TO your Bronco Sport today? 3D26C163-4D39-4580-96D9-3A5340D1DFC2
Ford Bronco Sport What did you do TO your Bronco Sport today? 700F2F55-76AA-44F7-80B0-5D5A7F1C64C9
Ford Bronco Sport What did you do TO your Bronco Sport today? 4DB8F6E1-0DF2-4ED7-A9B9-44DBF0D7B57C
Ford Bronco Sport What did you do TO your Bronco Sport today? 4AB6C91B-943C-46D7-8769-5AB7EF2D5D43
That is perfect, and it sets exactly as my first edition,it has a 1.5 left.
Ford Bronco Sport What did you do TO your Bronco Sport today? FB75C02F-89B7-4BFA-810A-228E09278054
Ford Bronco Sport What did you do TO your Bronco Sport today? 5F58E8F5-90AB-46FF-B24C-6BFA79FD73A8
Wolf256
Jane
Kingston, WA
Did this today, by myself. Still haven’t got the hood stops correct. I can tell anyone else going with this shield that the direction of 1 and 1/2 turns counter clockwise is not correct.
ETA: Turns out it was 4 or 5 full turns. The direction given in the instructions is counter clockwise. That just kept raising the hood. Clockwise was what lowered the hood stops. Also, for those, like me, that could have used a bit more instruction, you only have to remove the six tabs. If you have a second person it would be much easier to determine which of those tabs to remove. The shield isn’t heavy, just awkward.
