22-VelBlue
Salt Lake City UT
New Husky floor mats arrived! I could spill two gallons of water on these and not spill a drop!
Ford Bronco Sport What did you do TO your Bronco Sport today? 25196153-D008-465F-8376-D128A9E3DF53
Just put SmartLiners in mine...looks like we're twins.
Just put SmartLiners in mine. Looks like we're twins!
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220522_211253005
Did you order direct from Ford or did you find another outlet for these BL rims?
Bought it online from a reseller of take off wheels
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
I want to understand this wizardry. So, does it vent at a lower pressure and keep the PCV valve from dumping hot, thin oil back into the intake? I know Chrysler in particular feels the intake manifold needs regular lubrication.
"So, does it vent at a lower pressure and keep the PCV valve from dumping hot, thin oil back into the intake?"
It operates independently of the PCV configuration
As described it works as a oil cap during the active PCV negative vacuum
Nothing more than a cap
Under increased throttle the vacuum is reduced
At some points there is no vacuum
Case venting stops
It is at this point a potential for a rise of increased case pressures exists
Crankcase say hello to blow-by gases
The breather allows them only to make a quick visit before leaving
When PCV vacuum ceases and case pressures rise breather venting occurs
https://scholar.uwindsor.ca/cgi/viewcontent.cgi?article=6217&context=etd
Lots of vids...some good, some bad
search crankcase venting
dakman
Had the roof on my BB painted today.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653510219981
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653510257020
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653509746106
Looks good. I almost traded my BB for a bl last night. It was iconic silver and fully loaded but I just couldn't get past the black top. Funny cause when I first started looking at bs's I preferred the black top and now I just don't. Does look good though.
LilbroncoS
Brandon
2021 bronco sport
I love this. This is my plan as soon as I get mine in. Great look!
Funny h9w everyone tries to make there backs look like my base model.. im not much for the white letters either on Oxford white.. but doesnt look bad on all other colors
