Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
I want to understand this wizardry. So, does it vent at a lower pressure and keep the PCV valve from dumping hot, thin oil back into the intake? I know Chrysler in particular feels the intake manifold needs regular lubrication.
"So, does it vent at a lower pressure and keep the PCV valve from dumping hot, thin oil back into the intake?"
It operates independently of the PCV configuration
As described it works as a oil cap during the active PCV negative vacuum
Nothing more than a cap
Under increased throttle the vacuum is reduced
At some points there is no vacuum
Case venting stops
It is at this point a potential for a rise of increased case pressures exists
Crankcase say hello to blow-by gases
The breather allows them only to make a quick visit before leaving
When PCV vacuum ceases and case pressures rise breather venting occurs
https://scholar.uwindsor.ca/cgi/viewcontent.cgi?article=6217&context=etd
Lots of vids...some good, some bad
search crankcase venting
dakman
Had the roof on my BB painted today.
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653510219981
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653510257020
Ford Bronco Sport What did you do TO your Bronco Sport today? 1653509746106
Looks good. I almost traded my BB for a bl last night. It was iconic silver and fully loaded but I just couldn't get past the black top. Funny cause when I first started looking at bs's I preferred the black top and now I just don't. Does look good though.
LilbroncoS
Brandon
2021 bronco sport
I love this. This is my plan as soon as I get mine in. Great look!
Funny h9w everyone tries to make there backs look like my base model.. im not much for the white letters either on Oxford white.. but doesnt look bad on all other colors
BravoAlpha
Oklahoma
Washed mine..finally. Got it in garage. Bout to hit with polish and rainX
While under fluorescent light, find hail damage. :curse::curse::curse:
Looks excellent , it gives it the look .
Ford Bronco Sport What did you do TO your Bronco Sport today? DF72BC22-77F7-4DC9-9DD2-7A4C72732EBF
Ford Bronco Sport What did you do TO your Bronco Sport today? 02E5C121-1467-4EA7-AD85-E61146A763B4
MMR_A51OBX
Matt
Illinois
Got the ambient light cup holders installed on my 22 outer banks
Ford Bronco Sport What did you do TO your Bronco Sport today? 20220525_162617
Where did you get those? And how did you hook it up? I like it. I wish we could change the ambient light colors. My wife's Telluride has multiple color options.
MJE
Calgary, AB
fog53
ron
Both items ordered on Amazon. The console organizer tray fit perfect. The rubber center console cover went on very ray and looks like it will protect well. Wife says it is too rough on her elbow when she rests her arm on it but I'm pretty sure she will come around in the long run to like it. Also ordered the cargo organizer from Ford that should be here in a couple days.
