- First Name
- Matthew
- Joined
- Jan 28, 2022
- Threads
- 1
- Messages
- 4
- Reaction score
- 2
- Location
- Keystone heights, FL
- Vehicle(s)
- Bronco Sport, F150, F250
- Thread starter
- #1
I installed a buschurs catch can for a maverick 2.0. As many of you know one of the major problems in direct injection is coking that happens in the heads. This will also prevent your intercooler from clogging because this system is pre turbo. There is another system on the pcv side to but that
Install was fairly easy just used a razor to slit the old hose off and slid new hoses on. The instructions say to use old fittings and slide the hoses right on but I installed hose clamps. The hoses were not tight without.
I did have to modify the the mount for the can. I just bent it flat and drilled a hole where u can see in picture. I imagine on the maverick the fenders are more angular and bronco is more boxy where it mounts.
Iāll give in update with what it catches in a few thousand miles.
https://buschursllc.com/br-cart/home/1833-maverick-20-eb-oil-separatorcatch-can.html
