Went from 245/70
Ford Bronco Sport What did you do TO your Bronco Sport today? 44E2CF24-C43F-4FC3-B7B0-64B363A4FBB8
front
Ford Bronco Sport What did you do TO your Bronco Sport today? 537532C2-F738-4C41-89E7-DC6699DAA661
Rear
To 245/65 and then checked clearances
Ford Bronco Sport What did you do TO your Bronco Sport today? 876C8218-E910-44EC-B416-B99F8098A2D1
Looks like a lot of clearance in the last picture. Both above and below the tire! :cool:
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Yesterday
Spot this
https://www.broncosportforum.com/forum/threads/project-obronco.2688/post-102261
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651859901941
Pop the hood to make sure I don't already have one
Nope, just as I would have expected
Size it up
Looked pretty barren
Stark
Flat
Plastic
Remedy: Need this
Place order Fordparts.com late in evening
Delivery truck this AM
Done deal
Noise reduction
I believe so
Thanks for the part no's Glamdring70
Anyone have any intel on the (green arrows) four tubing ports?
Did first oil change and installed my new light bar. No lights yet but now I can decide which ones and they will hang down.
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220508_022125366
Ford Bronco Sport What did you do TO your Bronco Sport today? PXL_20220508_022049929
Which light bar is that?
Major Kong
Major
Ford Bronco Sport What did you do TO your Bronco Sport today? 1652195217328
Ford Bronco Sport What did you do TO your Bronco Sport today? 1652195286406
Rubber Rear Seat Backing
Base model BS
No seat mounted snaps
Preliminary set-up
Fasten using velcro
I'll let you know how it goes
Side note
Go to cash out
Hit the cashiers window
"I'd like to use Paypass points"
Oh, for that you need to go to the specialist window
"Howdy specialist. I'd like to use my Passpoints"
Oh, shows you have 42,000. You're good to go. Take your parts.
And AGAIN some how points are never deducted
Sure they'll find it someday
But until then
I'd have to say from the last couple visits I'm a pro at deficit spending
Think I'll run for Congress
Base model BS
Preliminary set-up
Fasten using velcro
Side note
Go to cash out
But until then
You can buy the button fastners in a kit . They are a very useful item . Enjoy
Ford Bronco Sport What did you do TO your Bronco Sport today? E8FA08BE-040E-4004-919B-E979EA67B5E0
Major Kong
Major
Not much luck finding snap fasteners
FordParts.com seems to suggest pop riveting???
Any link for a part number would be appreciated.
Rather take another approach than the pop-rivet
Say things get wet and you need to remove rubber mat
Rivet seems less favorable for removal purposes
After velco option No. 2 is push pin restraint
Ford Bronco Sport What did you do TO your Bronco Sport today? 1652211476290
Ford Bronco Sport What did you do TO your Bronco Sport today? 1652211527951
PonyDriver43
Roger
NE FLA
Yesterday
Spot this
Size it up
Stark
Flat
Plastic
Remedy: Need this
Done deal
Noise reduction
I believe so
My 12/23/21 built 2022 Outer Banks has this cushion device.
I thought it is an additional inflation device that inflated in the event the collision avoidance system failed. The green arrows point to the chip controlled ports that open when in SPORT GOAT mode so you can hear the Little Engine That Could better.
That's what I read on the infonet anyway.
:thumbsup:
Heh heh. I didn't drop that one here lest it lead to a run on the parts like the Engine Cover crisis of 2022. Glad you got in before the stampede!
I am still trying to figure out the other 4 plastic pegs. My belief is that there is some piece of hardware (like a brake cylinder?) that attaches to the firewall via the same push retainer system, in larger gauges. I have looked online at other Ford engine bays like EcoSport and Escape and haven't found anything. Maybe on the electric Mavericks???
