Weathertech Mudflaps
Econoline
socal
Finally got my WT mud flaps…took a month… installed tonite and fit really nice.I like em?
I'm about to order a F/R set. Just wondering if they are truly "No Drill" and use the existing mounting holes on our Bronco Sports?
Fordfan
Fordfan
Winnipeg, Canada
2021 BRONCO SPORT OB
Yup …no drilling. Pull some plugs out and screws go in their place. There are also some clips that hold them….super easy and don’t have to take wheels off. Really happy with mine
dannyc928
Danny
CA
Hi Fordfan. What is your opinion or experience with the clips that hold on the front mud flaps? Are they sturdy enough and will hold the mud flaps in place when driving in mud, gravel and rain? I fear the clips would pop off.
Fordfan
Fordfan
Winnipeg, Canada
They're fine ...just went through a real snowy winter and no an issue at all. There are a couple of screws that hold them too
Carolo
Chuck
Southern California Mountains
I got my WeatherTech flaps yesterday, along with the hood gaurd. Haven't tried the flaps yet, but the hood gaurd DID NOT FIT! The mount holes were in the correct places, but the gaurd was too thick (or shaped wrong?) to fit between the hood lip and the body, the latch would not close. Waiting for response from WT. Won't try the flaps until hood gaurd issue is resolved.
Carolo
Chuck
OK, flaps fit great and easy to install, (I'm 80 years old, if I can do it, ANYONE can do it)! WeatherTech is refunding the bug/rock deflector, it won't fit on my BL for unknown reason. Great company, help with no hassle, Stand behind their products!
FYI, only the front has to be drilled on the Ford versions and that’s into the plastic part at the bottom. Wheels also do not need to come off but those with larger hands will find the back ones a pain but that is the same I would expect with the weather techs as they use the same mounting points.
Carolo
Chuck
Dude! I volunteer to run a local pickleball club's website. You are using an online forum, therefore you are not an ordinary 80-year-old!
Thank You for that! My wife has said the same thing, but she's prejudiced! AND, thank you for being a volunteer, not enough of that going on anymore! Attached are some (poor quality) pictures of the flaps. And since the hood protector was a bust, I'm having the Ford Aeroskin II installed by dealer at the end of the month.
GaryCN
Gary
Livonia, MI US
Used my Cricut to add graphics to the WeatherTech mud flaps, installing the flaps was not too bad, the innermost screw on the rear was a little difficult with the tires on. Persistence got it done.
Ford Bronco Sport Weathertech Mudflaps WeatherTechMudFlaps_1
On3Adam
Massachusetts
2021 Bronco Sport Badlands
What Font and size did you use?
On3Adam
Massachusetts
So I got the weathertech mudflaps. Ended up using our cricut machine to put my own touch to it.
Ford Bronco Sport Weathertech Mudflaps C7082E2F-FA41-4E54-B8CF-B38229ABDFF2
