- First Name
- ledge
- Joined
- Nov 4, 2022
- Threads
- 1
- Messages
- 34
- Reaction score
- 40
- Location
- sayville ny
- Vehicle(s)
- ford
not sure of date sometime last yearWhen did they switch over to the B Version water pump?
Not sure if you seen posts about this yet but owners reported the 1.5L engine B Version water pump also can fail (leak).When did they switch over to the B Version water pump?
For almost everyone, it should be a warrantied item (zero cost). Cheers!What is everyone paying to have the water pump replaced on the 1.5l engine?
The procedure currently calls for a flush of the system incident to replacing the pump. Considering both parts and labor, $600 doesn't sound too far off the mark for a dealership. Since it's out of warranty there's no reason you have to take to a dealership; consider getting an estimate from a local independent shop. Many do not have the same level of overhead as a dealership service shop, so labor rates can be much lower.65k miles on a buddies. Dealer said $600…
Just curious - what is the year model of your BS and what was the mileage when you experienced the water pump failure? I have a 21 BB with 40K miles and have been monitoring my fluid level due to the stories on this forum - no problem so far…..At some point in the last 5k miles my water pump had an event and fail. Left coolant everywhere (not in my parking areas) and shredded my serpentine belt. The dealership is struggling with the belt replacement. Anyone else have this issue? It seems that it’s common here but the service writer told me not to believe the things I read here. For reference I’m located in north central CO.
