Vantrue E1 pro
VinnyLongPour
Vincent
Long Island
catrikejoe
Missouri
2025 Bronco sport Badlands wife owns a black 2024 Bronco sport Badlands
catrikejoe
Missouri
FYI the Bronco Sport has USB-C ports not Micro USB
Yes your correct, will that camera run? Reason I'm asking just tried to one it wouldn't.
As long as accessory power is on or the engine is running, those ports are both powered. My E1 runs perfectly fine from it. I did get a 6" USB-C cable to cut down on clutter.
Ford Bronco Sport Vantrue E1 pro IMG_0196 (1)
catrikejoe
Missouri
Thank you that's the set up i want to do.
VinnyLongPour
Vincent
Long Island
i haven't plugged mine in there yet but at least 2 others on this forum (including the OP) have this exact dash cam running from the accessory tray USB port.
catrikejoe
Missouri
well i purchased that camera went through all settings no problems except for Wi-Fi it wants to connect to connect thru my dash Android auto Wi-Fi instead of my home network. So my Question is is this normal and also the camera won't continue past phone app set up even though it tells me connected to Wi-Fi. any suggestions would be great thank you.
