- First Name
- Tom
- Joined
- Jun 7, 2021
- Threads
- 37
- Messages
- 869
- Reaction score
- 1,068
- Location
- Los Angeles Metro
- Vehicle(s)
- 2021 Bronco Sport
Article from a website.It wasn’t the turn signal bulbs it was the brake light bulbs. They weren’t getting bright when I hit the brakes. I replaced those and the hyper flashing went away. The dealership was swearing up and down that it could be the bcm.
Replacing your indicator bulbs is much the same process as any other light on your vehicle, but with one important difference. Your car’s indicator wiring circuit has been set up for incandescent light bulbs which offer a particular amount of resistance. In comparison, LED lights offer little electrical resistance – and in layman’s terms this means your car’s indicators may “hyper flash” (flash very quickly) if you replace all the bulbs with LED’s.
In order to fix this, you must either purchase LED bulbs which are advertised as having the correct amount of resistance built in, or you’ll need to purchase separate resistor units which must be spliced into the wiring circuit to slow the flashing back down to the normal speed. This is obviously a more involved process, so if you aren’t confident with the job I certainly wouldn’t tackle it yourself without doing some research first and having the necessary tools.
