- First Name
- Sherman
- Joined
- Dec 1, 2021
- Threads
- 31
- Messages
- 1,877
- Reaction score
- 1,978
- Location
- MIDDLETOWN, MD
- Vehicle(s)
- '22 Badlands ordered 12/17/2021 - Arrived 3/25/22
The Bronco Sport (and essentially every modern vehicle) is *negative* ground. This photo shows the negative battery terminal connected to the fender:Thanks for all of the responses.
I drive a work Tacoma everyday, so I often can’t really plan when the BS is going to be used. Husband drives our F150 but he should share use with the BS more often as it’s more economical. If it’s not wet and muddy out, I’ll take the dogs out in the BS but if it is wet & muddy I’ll take our old Nissan Frontier. Needless to say, it could be daily or not once all week.
Plus, temperatures aren’t always -20°c and colder. Today we are hovering around -11°c, for example.
I like the idea of hard wiring the battery maintainer and plugging it in as required, and purchasing a 3 foot extension so I don’t have to pop the hood every time to use the block heater. I like to remote start the BS daily if I am not using it, but I figure that it won’t remote start when the hood is ajar, so that’s annoying until I get an extension. But I wouldn’t know where to begin about hard wiring. I have the instruction manual, how do I know if the BS is a negative or positive grounded vehicle?
Having the Battery Tender hardwired would be convenient. I've never done that because:
a) Inertia -- it's easier to keep doing what I've always done.
b) They are not designed to be mounted under the hood of a vehicle (if that's what you had in mind).
c) I have several Battery Tenders now, but in the past I would use them on more than one vehicle. I still do that with one of them -- it gets swapped between two of our older cars.
The engine compartment of a car is a very harsh environment. BT does not mention mounting a unit under the hood (one way or the other): https://www.batterytender.com/
What they do recommend is permanently connecting the 12V extension with ring terminals, and routing the connector to an accessible place. Maybe that's what you meant. That's what I've done with our Suzuki, because the battery is difficult to access.
There is obviously no concern about sparks when connecting just the extension with ring terminals, so you do not necessarily have to make the neg(-) connection away from the battery. I haven't looked to see if there is an obvious/easy connection point.
Regarding starting the BS every day, it's better to drive it, even if that is every week or two, because that way it will get fully warmed up. Extended idling is often listed as a "severe service" factor for determining oil change intervals.
BTW -- coincidentally, I've been looking at short 120V extension cords, and I found that Amazon is MUCH less expensive than Home Depot. Note -- many of the extension cords Amazon sells are not ETL or UL (or CSA) listed (but many are).
Good luck!
