- First Name
- Sherman
- Joined
- Dec 1, 2021
- Threads
- 31
- Messages
- 1,876
- Reaction score
- 1,977
- Location
- MIDDLETOWN, MD
- Vehicle(s)
- '22 Badlands ordered 12/17/2021 - Arrived 3/25/22
I caught that "14%" -- but I believe that was based on comparing the amount of weight (in grams) lost from each, and they started with different weights. Not wildly different, but when someone is being as precise as he is, an error like that kinda stands out.At around 2:52 he says the 10k oil experienced 14% less evaporation than the 5k oil.
Just goes to show how hard it is to untrain our brains once we get an idea ingrained in there. This guy is clearly data-oriented, but he just can't bring himself to trust the data.
Back to the Owner's Manual:
Again, no big deal, it doesn't affect the outcome, just something I noticed.
Thanks for the correction (10K vs 12.5K miles). IDK where 12,500 came from. I wasn't absolutely sure, that's why I qualified it with 'IIRC'. I am reasonably certain I saw it recently here in a post about the OLM. Maybe it was a different vehicle?
I don't exactly have a photographic memory, and I post in several different (and mostly unrelated) forums. If I'm really not sure about something I'll take the time to research it, but I'm almost never 100% certain about anything that depends on memory. If I checked everything I post that I have even the slightest question about, it would really slow things down.
In this case, my overall point remains exactly the same either way -- quote:
"For other drivers that may be wasteful. After all, the OLM in the BS goes as high as 10,000 miles (IIRC) and that's assuming the Motorcraft synthetic blend oil is being used.
So his statement that the oil cannot be trusted beyond 5-6,000 miles in clearly false in many cases. In fact, while I am NOT recommending this, based on the video, when using full synthetic, the change interval could be extended beyond what the OLM indicates. Again, I'm not suggesting anyone do that, I'm just pointing out that when he says "5-6,000 miles" that would be very wasteful -- esp when using 100% synthetic.
As you said: "Just goes to show how hard it is to untrain our brains once we get an idea ingrained in there. This guy is clearly data-oriented, but he just can't bring himself to trust the data."
That's spot-on. I think most of us have thought that way at least once or twice.
