- First Name
- Woody
- Joined
- May 1, 2021
- Threads
- 4
- Messages
- 32
- Reaction score
- 53
- Location
- WAAAAAAAAAAAY Up North
- Vehicle(s)
- 2021 Bronco Sport
Full synthetic, synthetic blend, or full conventional oil (which does not come from dinosaurs, but is largely made up of decomposed plant material) really doesn't matter in regards to how long the engine will last. The only difference is lifespan of the oil. Conventional oil should be changed between 3-5K depending on the additive package/type of driving/driving conditions/additive package. Data from a 20 year old study is no longer relevant as the oil technology for even conventional oil has changed dramatically over the years. Synthetic blend and full synthetic can last much longer, again depending on use, conditions, and again additive packages. The only way to know for sure what your typical oil change interval is to get the oil analyzed by a reputable lab.
I personally live in an "extreme" environment. Winter temperatures reach -20* F (actual temp, not windchill which is a ridiculous number) in the winter. Because of that, I change twice a year regardless of mileage and run full synthetic. Summer I run 5wX depending on the needs of the car (my Acura uses 5w20, our Edge used 5w30, my Thunderbird uses 5w30, I believe the B.S. uses 5w20) and in the winter I change them to 0wX oils (except the Thunderbird, which doesn't get winter use). Based on personal experience, I've never had cold cranking issues running 0w oils in the winter. A side by side comparison with one of my former cars (2002 Crown Vic, 4.6V8) running 0w30 in the winter vs the work vehicle I had at the time, a 2007 Caravan panel van that my employer only put conventional 5w30 in, the Crown Vic started first crank every time, even below -20F, while the Caravan would literally scream until the oil started to flow.
I will run full synthetic in everything I own just for the better flow on cold startup alone. If you live in a more temperate environment, conventional oil works fine, and there's nothing wrong with it. If you want to run synth blend, fine, nothing wrong with it, and of course, nothing wrong with full synthetic.
