No I wasn't asking a question about itIf I understand your question, you are asking if a full-synthetic is better for the engine than a synthetic blend. If you follow the recommended change interval I don't think it matters.
Engine oil has many duties, but the two most important are lubrication and keeping debris and corrosive contaminants away from critical engine parts. I've already discussed lubricity; according to the lab experts any oil you use that meets manufacturer specs will provide satisfactory lubricity.
Over time, use and heat will cause oil to break down, which is another way to say it will lose lubricity. Heat is one of the things the intelligent oil-life monitor, er, monitors to determine the change interval. Since full synthetic is less affected by heat you could almost certainly use it longer than semi-synthetic without worrying about lubricity. But heat-related loss of lubricity is not the only reason for changing the oil.
Engine oil also sweeps harmful debris out of the engine by carrying it to the filter, where it's captured and held until the next change. Likewise, corrosive contaminants such as combustion byproducts are held in suspension in the oil until the next change, and then drained out with the oil. If the oil gets too contaminated then lubricity begins to suffer. Oil contamination is also part of the equation when the oil-life monitor computes the change interval.
All of this is to say as long as you use an oil that meets the spec and change it as recommended you should be golden. Using a better (full synthetic) oil and changing it more often will neither help nor harm your engine.
My advice is if you're at all concerned with environmental considerations stick with the recommended change interval. Using less oil is a good thing for the environment, and Ford spent billions in research to set a change interval that's safe for the engine.
was pointing out that's very scientific verbage 'molecular level.'
It's hard an interesting dilemma to get people's feedback pertaining to the molecular level of things ?
Thats all.
Wasn't asking how oil works thanks though I'm so sure someone will appreciate that
