Rocker switch panels or a wireless option recommendations?
Sargent28
J
67 Mustang
Installing the nudgebar with pod lights and wanted to know if anyone had recommendations on rocker switch panels or a wireless option thats good quality?
Reklussloth
Colton
2021 bronco sport
I had this same argument withmyself last night... and decided for now im gonna run the little mouse style rocker switches that are self adhesive. Down low near the hood puller.. not sure what all switches i will need before this is done so i didnt want to commit to anything permanent
Reklussloth
Colton
2021 bronco sport
Similar to these but i think i got marine ones....just did a nudgebar last weekend so if you have any questions just ask
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? Screenshot_20210712-183015_Chrome
JTAV8R
Jay
Williamsburg, Virginia
endrMinr
Albuquerque
'21 Bronco Sport
Take a look at the Trigger Series. https://triggercontroller.com/
I bought the Trigger 4 Plus https://triggercontroller.com/trigger-controller-4-plus/ for my BB after installing the nudge bar and lights. Working on a stand to mount it under the hood now. Pictures to follow when I start the process. I've installed the nudge bar and one set of lights...waiting on the second set now (backordered).
I am looking to install AUX switches as well and saw this kit, I am debating a 3D printed mount that will fit in that small shelf space right below the multimedia center, seems like a good place to put switches and I dont use that space for much of anything else.
Nyeagle
Matt
FL
where did you mount it and did you hookup the Yellow ACC wire to the battery or to a ACC wire?
dejones64
Dan
MN
Lancer, BS BB
Is there a way to run something like the Aux Switches on the big Bronco, replace the sunglass holder?
JTAV8R
Jay
I installed two brackets on rubber isolation mounts to existing holes already in the drivers fender well. I also put a rubber bushing between the plate and the brackets to reduce the shock and vibration to the unit. This unit is heavy duty from the factory, but you never know. Originally I had it wired directly to the battery. I have since ran it to an auxiliary ignition point on the fuse box.
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? IMG_0464
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? IMG_0462
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? IMG_0468
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? IMG_0484
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? IMG_0478
Nyeagle
Matt
FL
Which fuse did you use for acc wire?
Nyeagle
Matt
FL
This was my final placement. Found some old brackets that fit perfectly. Decided to keep it always hot and wired it straight to the battery.
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? 20210925_163318
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? 20210925_163323
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? 20210925_163325
Megakatx
Gerardo
Durham, nc
I'm in the same boat... did you still have the acc yellow cable) connected to the battery, is not killing the battery all the time?
Does anyone know what the "WIRING PREP-PACK" listed on the window sticker is? I thought maybe it was pre-wired for accessories.
VirtualJMills
California, US
Some hypotheses as to purpose, but no formal statement from Ford on exactly what that line-item includes.
Likely includes items in the Badlands / First-Edition trim level like the Driver's A-Pillar wiring harness for roofline lightbar.
Some of us hoped it also included the appropriate front-to-back harness for retrofitting the tow kit by dealers, but so far no joy on that.
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
That is one thing I love about my FJ is that they gave “blank” switch in the dash where you could add the lights etc into the existing switch area.
Ford Bronco Sport Rocker switch panels or a wireless option recommendations? C1F8DBE3-5A80-4471-AD76-3A9DAB7526CD
CallMeBill
2022 Carbonized Grey Badlands
Jay - How did you wire the 4 lights to the Trigger 4 plus? Are they all on 1 circuit or did you split them up? If you did put them all on 1 circuit what/how did you do that? I am debating between getting 4 lights like you or a LED bar instead.
