- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,152
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Out of curiosity, did you check with your service department just to make sure you're doing it right?Giving update. I was able to get it all together. If you open the transmission check plug while the vehicle is off, you will lose an additional 1 to 2 quarts. It is meant to be opened while the truck is running, and hot. I would add some to the fill port with the vehicle on and hot, then, open the check port and let the excess fluid drain out. If you do this several times, you will actually do a partial "flush" as the transmission fluid is being circulated at all times. I have driven it well over a thousand miles since I put it all together and everything is fine
