Powertrain Malfunction / Reduced Power warning.
roger905
Roger
Virginia
2017 Escape
I've had my BS almost 2 weeks, 1,000 miles and got the above warning. Have others had this issue?
Fossil
Ernie
ohio
any back story?
roger905
roger905
Roger
Virginia
2017 Escape
any back story?
Not much of a back story. Normal driving (all miles have been on paved roads) it just came on and started to run real ruff. Lost cruise control, drive modes. Since it has sat for a while those issue appear to be back (parked in the yard, I haven't driven it since I got home). It is idling very fast, running up to 3,000 rpm. Waiting to hear back from dealer. I was just curious if others have had that warning show up.
fourthgear
florida
There has been a rash of corroded wiring connectors , where harnesses have had to be replaced , so hopefully thats all it is . The Dealer will also hopefully take care of it .
McBrideless
Oklahoma
Buick Lesabre
I had that warning. I just got it back after being in the shop for two weeks to replace the rear drive unit. I don’t know if that can really tell you anything though, because it’s a pretty broad warning that could be from a wide range or issues with varying severity
Bronclahoma
Oklahoma
This is a problem, both the ECU and an electrical junction box near it are below the depth that Ford claims the Bronco can traverse. They need move the location pronto and do the same with any units in for warranty for corrosion problems. I'm sure I'm not the only person that is wondering what is going to happen if I do a water crossing. I knew there would be first-year production issues, but that doesn't mean I don't expect more from Ford.
roger905
roger905
Roger
Virginia
2017 Escape
Last Thursday I got the Powertrain Malfunction/Reduced Power warning along with a couple of others. It ran horrible and I lost numerous functions, cruise control, drive modes and so on. I had it taken to the dealership and just got it back this afternoon. The problem was a broken vacuum plug. They replaced it and it runs like new (which it is ?)
DISCOLEG
So, I've seen similar issue somewhere else on this forum but they could not figure out what was happening.
In a manual I've come across something.
There is a safe mode if your engine gets too hot and only 2 cylinders used to drive and the others to pump air in to cool it.
Check your coolant if you have reduced power.
Bronconumber5
Carrollton,Va
My wife started experiencing stalling, hesitation, and lack of power when the car hit 1100 miles. We barely got it back to the dealership without a tow. The dealership performed the diagnostics and found a faulty high pressure injection pump. The pump was replaced and the problem was fixed. the service department was great. The part was pulled from production line on an emergency basis. We were advised that at that mileage there has been numerous failures.
SM05
West Virginia
