Kq100
Kris
Wyoming
Outback
Similar but we went with Yakima Lock and Load platform
MRanderson
MRanderson
Jared
Chino, CA
yuccamanufacturing.com
Bronco Sport Big Bend
Looks great! What's the make and model of this rack system?
Itā€™s actually my own design. Iā€™m an engineer in manufacturing and decided to make it.
You can use it with or without the accessory brackets shown
Everything is able to be reproduced if anyone is interested.
pixlpush
Sean
Portland, OR
Tern GSD Ebike (car free at the moment)
Very nicely done, what's the weight?
MRanderson
MRanderson
Jared
Chino, CA
Sweet! How'd you go about mounting to the factory rails?
I designed and made steel brackets. The pic is during prototype, after Powdercoat I use rubber tape for the contact points to the roof rails so they donā€™t scratch.
the brackets have an angle piece so they are touching the roof rails on 3 sides and are very strong
Ford Bronco Sport New Custom Overland Roof Rack for the BS 092C6C8E-5161-40AB-AAD6-0AB2F6BAFEF4
Econoline
socal
Is there a way to delete the factory rack and mount directly to the channels underneath it?
MRanderson
MRanderson
Jared
Chino, CA
Iā€™m sure there is, but we did this recently on a buddyā€™s Escape only to find the oem rails were held on by 3 very small screws. The oem rails are going to fit best to the car and wonā€™t scratch it and be rain proof, displace load well, and help raise the rack to clear the sun roof - which the BS sun roof sticks out the roof a lot and will cause clearance with a lower profile rack.
it just made the most sense. Also easier removal and install of the rack
my rack DOES clear the sun roof!
MRanderson
MRanderson
Jared
Chino, CA
Seems to be overkill
Can only carry 30lb of stuff after the rack is installed.
Ford Bronco Sport New Custom Overland Roof Rack for the BS 06C2E3E2-ECA1-475D-9022-F80B0D25F4B2
dynamic load of 150lbs, minus the rack thatā€™s 80-90lbs of weight you can store while driving. 520-530lbs static load after the rack install, Seemed worth it to me
