- Thread starter
- #1
Howdy everyone,
First off want to say the bronco sport big bend is the best compact suv for light off roading and it being your first vehicle.
Anyways, I hit a curb and now the bearing in the rear lower control arm is destroyed. So I decide to be a responsible car owner and try to replace the entire control arm by myself. I have done a couple of mechanical works here and there and I always follow the manufactures or expert advice. and if given advice I ensure to learn more about it. Anyways as I removed the lower ball joint, and rear bearing I hit a wall and saw a subframe bracket shield covering the bolt head or nut I need to screw off. I then remover the outer tire rod end, and the sway bar to give me some more room.
really bummed out I was moving along so well and get stuck on something like this.
Does anybody by chance know how to take off the front bearing of the Lower control arm that is cover by the shield for the subframe brakes that cover the "ears" of the subframe where the front bearing is clamped in a bronco sport.
