Need Help Customizing the Display
rugedraw
Javier
Miami, FL
So, on the menu I picked, My View, and it uses to give you options as to what you want to see, including the calm mode, looks like with the last update, that is no longer the case as when I choose the My View, I dont get any options and it goes right back to the regular View ☹ oh and I have a 2025 Outer Banks.
Do you have the details of the update in your Fordpass or touchscreen? Do you know what module was updated?
Schuelady
Tami
Nebraska
Something definitely doesn't sound right. I still occasionally get the random "reset to default" and have to go back in and change them all back to my preferences.
So, do you think mine has a glitch? Next time I drive it, I'll see if it still does not give me options.
Schuelady
Tami
Nebraska
I'll have to look and see if the update details are in there.
Schuelady
Tami
Nebraska
So, it looks like the last update was to eliminate the false check engine light, which I never did see on mine.
2025 Badlands Sasquatch
So a "the patient died, but the operation was a success" scenario.
rugedraw
Javier
Miami, FL
PT-25.1.3.1? If so, that is a PCM update. Hard for me to imagine how that would affect what you can see in the cluster, but if more than one owner is experiencing this after the same update, maybe there is a correlation.
dwrufus53
Don
Phoenix metro
I just checked my 2025 Bronco Sport Big Bend and these are the screens associated with My View. Also my Ford Pass app shows no updates done or pending.
Ford Bronco Sport Need Help Customizing the Display IMG_3917
Ford Bronco Sport Need Help Customizing the Display IMG_3918
Ford Bronco Sport Need Help Customizing the Display IMG_3919
Ford Bronco Sport Need Help Customizing the Display IMG_3920
Ernest T
Ernest T
Dennis
Central Texas
I just checked my 2025 Big Bend and these are the screens associated with My View. Also my Ford Pass app shows no updates done or pending.
You can do that without engaging one of the GOAT modes?
dwrufus53
Don
Phoenix metro
Yes. I was in "Normal" mode. AFAIK, the only display settings affected by various GOAT modes are the "Configure Gauges" setting... where there are a couple of additional gauges available in Off-road and performance modes.
Schuelady
Tami
Nebraska
So, yes mine is no longer giving me those options! I had a friend of mine that has the same year and trim I do, show me hers, and hers is working also. It may just be a glitch and hoping next time I try it, it will work, otherwise I'll be calling the dealer to take a look.
Ernest T
Ernest T
Dennis
Central Texas
I don’t get those options on my 2025 Bronco Sport.
Schuelady
Tami
Nebraska
Okay, well I hate to admit this buuut, I had a senior moment!! 🤷‍♀️🤦‍♀️ So, when I tried it again, I realized once I hit the My View, I have to push the button up or down for the screen to change options to select!! Sorry if I confusing anyone!! Anyway, I'm glad its working!!
smcBronco
Sean
Ocean Shores, WA
Ford Bronco Outer Banks, Alfa Romeo 4C, Smart for two
Yeah, well selecting "configure gauges" does nothing.
You have to be in "Sport" mode to add/change gauges. It only adds two at the top, Turbo Boost, Oil Temp, Trans Oil Temp, Volts. Pick 2. The "Swap" option only swaps the two added gauges.
dwrufus53
Don
Phoenix metro
LOL. I get it. I'm old too, and have had too many of those moments! :D
