- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,154
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
The attached PDF is a list of all the tires Falken manufacturers and sells under the A/3TW model name. A quick scan of the list reveals that every tire on the list is different from every other tire on the list. Falken sells A/3TW tires featuring MANY different ply ratings, tread depths, U.T.Q.G. ratings, etc. I've read through the marketing material about the A/3TW on Falken's website a couple of times now looking for something that could be considered misleading about the way Falken describes its A/3TW line of tires as applied to the OE tire Ford offers. As far as I can tell everything it says about the A/3TW model applies to the OE tire. What am I missing?The OEM size of 235/65/17 is much lighter and less aggressive than the other sizes of the same tire. So much so that some question whether it should even be called a AT3W (disclaimer, I have them on my Sport). However, if you order a 235/65/17 in that tire you get that same OEM tire. That is the one they sell to everyone, it just happens to be different than all of the other versions/sizes of the same tire.
The problem with statements like this is they are speculative. Now I'm not opposed to speculation when it's based on logic and might actually serve to help someone. But comments from a dealership that suggest OEM tires are "lower quality" lead to all kinds of unhelpful speculation and assumption. For example, someone reading through this thread could easily take away an assumption that tire manufacturers make two versions of the same tire, one for OEM installation, and another for retail sale, and the OEM version is somehow inferior to the retail version. I don't see how does this kind of speculation/assumption can help anyone.Thus, the dealer is likely correct. Chances are Michelin contracted with Ford for the OE tires for the OB the same as Falken did for the optional 235s. Ford has requirements regarding weight and ride quality that Michelin would likely consent to for that particular size of the Primacy. This means that it will likely not wear the same as the other counterparts at different sizes that are not operating under these conditions. Chances are Michelin still sells this size to all persons aftermarket as well, much like Falken.
If someone has evidence (actual data, not comments from a service shop that wants to sell you "better" tires) that tire manufacturers produce lower-quality tires of the same model as those they sell to retail customers please share it. I've looked, and I haven't seen any.
Any owner who's curious can look at the tires on their car to get an idea of how they should perform. The numbers on the sidewall tell the tale. Although not "gospel," the Uniform Tire Quality Grade (U.T.Q.G) ratings provide some clues on what you can expect regarding tire performance. If you believe the tire that came on your car is lower quality than the same tires the manufacturer sells at retail then go take a look at the numbers on your tire. You can compare those to the numbers on the retail tires. Then you'll have DATA on which to speculate rather than opinion.
TL;DR: The fact that you only got 20K miles from a OE tire that the tire's manufacturer warrants for 55K when sold retail is not evidence that OE tires are inferior. There are any number of factors that affect tire tread life.
