Horn Blaster Train horns with air hose adapter. Tank and compressor installed in spare tire area. Air line and wiring thru the pillars up and in split horns to each side. I wire tapped the main horn so it goes off even for the alarm.Any body replace there horns with F 150 horns or something louder than our Sport horns.
I bet your neighbors just •adore• you if it goes off accidentally.I wire tapped the main horn so it goes off even for the alarm.
yeah, I wish our horn had just a little more umph to it.Any body replace there horns with F 150 horns or something louder than our Sport horns.
Only happened once when the remote was in my pocket. Most times I walk in and drop them on the table so it's not an issue. Actually a friend said I want to hear your horns, I was like let's go fo a drive. That video I posted does not do those any justice.I bet your neighbors just •adore• you if it goes off accidentally.![]()
What about something like this?Any body replace there horns with F 150 horns or something louder than our Sport horns.
Overkill, but I like it!!!!!!What about something like this?
Not really looking for air horns just something that's a bit louder than our stock horn, Thought maybe full size Ford pick up might be louder, Can anybody confirm if it is ?Overkill, but I like it!!!!!!
I have replaced horns in many cars. As long as you can fit it in the bay and the voltage/wiring works you should be good. Horns are easy to replace usually. most horns are operated by a switched 12-volt power feedNot really looking for air horns just something that's a bit louder than our stock horn, Thought maybe full size Ford pick up might be louder, Can anybody confirm if it is ?
We don't use horns in North Carolina. It's considered impolite.?Any body replace there horns with F 150 horns or something louder than our Sport horns.
