Help! 2022 Big Bend 1.5L Oil Capacity
Barry S.
Barry
Holly Springs NC
I use the TLAR method--seems to've worked for the past 40 years or so.
Before I lost sleep wondering what TLAR means so I looked it up on Google. I went through numerous definitions until I found one that looks about right.?
jkeaton
Greatest country on earth!
This one
I want to know what everybody does with the .4 Qts. that are left in the container?
I mix it up with some gas and use it as weed killer.
Something about flying...... ?‍♂
Colonel Angus
Dean
New York
LOL T...hat L...ooks A...bout R...ight
cprcubed
Patrick
Parker, TX
I don't get it... I have a '22 and it only takes about 5.5qt. I use Take 5 Oil change and watch them add the oil. I am only billed for 5.5. They even show me the dipstick as full.
What gives?
Go back to post #13 in this thread and you will have your answer. Cheers!
JC3
College Park Md
2022 BS
Same for our 22 Big Bend, composite pan holding 6.6 quarts. Confused me at first until I found this thread and then found the card in our dealer docs. Interesting that the VIN shows the vehicle with a steel pan....
I am changing the oil in a few days and am always nervous about reinstalling the plastic drain plug. I purchased new O-rings but would like to have a new drain plug as well. I can't find the part number anywhere including calls to Ford's customer assistance and 5 dealerships. None of the people I spoke with seem to know anything about the composite pans on our vehicles!
I found this part number for the Escape (KX6Z-6730-B) but not sure it is the same.
Does anyone know the correct part number?
rneal55555
Russ
Milton, NH
I would bet they are the same they measure from the top the size of the pan most likely wouldn't have changed where the upper level of the oil needs to be so that it is clear of the connecting rods and drains from the top of the motor
Summers22
Jon
2023 OB with the 1.5L and I assume the 6.6 quarts is with the filter change and putting everyone at the full mark?
cprcubed
Patrick
Parker, TX
That is correct ... if you have the composite oil pan with the plastic o-ringed drain plug. IIRC, it was a mid-2022 change in the oil pan. If you have the metal oil pan with a standard hex drain plug it would be less. Cheers!
Summers22
Jon
My research leads me to believe all 23s have the 6.6 quart capacity.
