- Joined
- Feb 4, 2020
- Threads
- 17
- Messages
- 343
- Reaction score
- 383
- Location
- Arizona, USA
- Website
- discountti.re
- Vehicle(s)
- All Things FORD
- #46
Welcome to the forum, Dennis and congratulations on the new rig!Getting BS BL any day. I want to drive from dealer lot to Discount Tire, about 1/4 mile away, to have some KO's installed. I want 245/70/17 tires on the stock 17" rims (.17" CARBONIZED GRAY ALUM WHL) but your website won't let me select them.
My apologies for the troubles with selecting the larger plus size. There are a few steps you will need to take in order to get the 245/70R-17 to populate.
When searching by vehicle and after entering the vehicle details, you will be prompted to select the O.E. tire size. After this has been selected you will see the option to select "see more tire sizes"
After selecting "see more tire sizes" go ahead and click 17" and this will populate additional 17-inche sizes. Note, the 245/70R-17 is not an option at this point.
Once the additional 17-inch options are displayed, you'll then need to click "oversized tires"
After the "oversized tires" has been selected, you'll see additional plus sizes which includes the 245/70R-17.
It's important to note that these larger tire sizes match your original wheel diameter but may require new wheels or fender modifications to prevent rubbing due to the tire height, and may impact speedometer accuracy/vehicle handling.
With the 245/70R-17 size specifically, new wheels are not needed as this tire size is safely run on the factory 17x7 wheels, however some plastic trimming may be needed to avoid tire rub at near full lock of the steering wheel.
