- Thread starter
- #1
Manual book from Bronco Sport says not to use cover cuz you can damage the heated system by doing so. Should I strictly follow this and don't do it or they're just covering their butts?
Likely to protect yours.Manual book from Bronco Sport says not to use cover cuz you can damage the heated system by doing so. Should I strictly follow this and don't do it or they're just covering their butts?
It does gets hot! I've only used on the first level, second one already burs, haven't used the max.Likely to protect yours.
Several posts on this forum mention heated seats get very hot in Bronco Sports.
I can’t imagine it does any more damage then covering it with your body. When your sitting there your weight plus the fact you don’t vent would seem to be more of an overheating issue. Aren’t your clothes basically a cover between you and the seat? The cover may help vent it and your butt. LolIt does gets hot! I've only used on the first level, second one already burs, haven't used the max.
Yes, I probably shouldn't do it for now. Thank you!
Your body is a heat sink. Heat generated by the seat heater is conducted away from the heating element and into your body. If you put an insulator--like a seat cover--between the heating element and your body less heat transfers to your body. That heat is retained by the heating element. Is it enough to cause damage? It seems Ford believes so...I can’t imagine it does any more damage then covering it with your body. When your sitting there your weight plus the fact you don’t vent would seem to be more of an overheating issue. Aren’t your clothes basically a cover between you and the seat? The cover may help vent it and your butt. Lol
Yes, I'm adding another layer of insulator, but if I wear jeans, a jacket... clothes would affect more than a thin seat cover as long is not made by some flammable material. Isn't that right?Your body is a heat sink. Heat generated by the seat heater is conducted away from the heating element and into your body. If you put an insulator--like a seat cover--between the heating element and your body less heat transfers to your body. That heat is retained by the heating element. Is it enough to cause damage? It seems Ford believes so...
That is my thinking too. I could be wearing really thick clothes and the manual doesn't say anything about it. This is literally the warning on the manual:I can’t imagine it does any more damage then covering it with your body. When your sitting there your weight plus the fact you don’t vent would seem to be more of an overheating issue. Aren’t your clothes basically a cover between you and the seat? The cover may help vent it and your butt. Lol
I guess it depends on the insulating qualities of the cover you use. Since it’s highly unlikely Ford expects owners to drive naked, the specification almost certainly accounts for the insulating properties of clothing. Based on the warning in the manual, the spec doesn’t account for clothing AND a seat cover. Is it likely Ford is simply engaging in a bit of CYA? Probably. But as you say, time will tell.Yes, I'm adding another layer of insulator, but if I wear jeans, a jacket... clothes would affect more than a thin seat cover as long is not made by some flammable material. Isn't that right?
I used the seat heater today for about 15 minutes on the way to a local trail. I had it set to high--it's a bit cold today! Since I was going for a walk I put my gloves under my thigh so they would be warm by the time I got to the trail. When I pulled the gloves out from under my leg the seat where they had been sitting was HOT. I don't think putting anything on the seats is a good idea if you plan to use the heaters.As to the warning about the seat heaters, why question Ford? I’m guessing something happened at one point that made them say that. Why is so tough to just accept that the manufacturer knows more about its product than you?
Exactly. The heaters were designed to work correctly on a bare seat.I don't think putting anything on the seats is a good idea if you plan to use the heaters.
