Full view not available (rear view camera)
Raven
PA
2020 EcoSport, 2025 Bronco Sport Big Bend
When I turn on my rear view camera to check on my cargo hauler there is a black box that says, "Full view not available." Is there a way to turn this off so I can get a full view?
Thanks!
Ford Bronco Sport Full view not available (rear view camera) rear cam
dwrufus53
Don
Phoenix metro
AFAIK, no. I find it somewhat annoying, as well. I find it more annoying that the view would be more "full" without the "full view not available" banner appearing on the screen.
You can't make some of this stuff up.
Raven
Raven
PA
LOL I hear you!
Thanks
Raven
Raven
PA
Javier, I am guessing FORScan is software? Where do I get it and how do I use it?
Thanks
rugedraw
Javier
Miami, FL
It is. You would need a windows based laptop and a $30 cable from Amazon linked below. The software is free for a 2 month license, or $20 for a year. You can get it at www.forscan.org. The cable is:
https://www.amazon.com/Vgate-vLinker-Diagnostic-FORS-can-Scanner/dp/B0C3B11S7F/ref=pd_sbs_d_sccl_1_2/000-0000000-8675309?pd_rd_w=l6uHp&content-id=amzn1.sym.aa738fbd-ad05-4d11-aae2-04b598db6305&pf_rd_p=aa738fbd-ad05-4d11-aae2-04b598db6305&pf_rd_r=A72FGMDXPGFGQW672FC2&pd_rd_wg=GhrVN&pd_rd_r=ae8de797-073f-493f-98fb-5f93fb7de7f7&pd_rd_i=B0C3B11S7F&psc=1
FORScan tutorial is here. You can also look up some tutorials on YouTube if you learn better that way. Do not let it overwhelm you. It is very easy to use.
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit?tab=t.0
rugedraw
Javier
Miami, FL
All that needs to be done is change this one bit to enable RCOD (rear camera on demand) w/o the blackbox. Why Ford thought it would be a good idea to have that message in the middle of the screen is beyond me.
Ford Bronco Sport Full view not available (rear view camera) 1772743759722-5i
JAM486HP
Jay
2025 Bronco Sport Badlands, 2024 Mustang GT Premium
Now just need FORScan to turn license plate lights off when in reverse... the glare on the cam is a poor design
rugedraw
Javier
Miami, FL
I’ll agree to this 100%.
The only thing I can find in the BCM that you can try is this. If you don't get the desired result, just change it back. This is from the BCM of a 2025 Maverick. The BCM in my F150 is very different. This is what your BS shows there:
Ford Bronco Sport Full view not available (rear view camera) 1772754586321-su
This means PWLLC is disabled. F it.....enable it to see what happens. Change the 9 to a D, reboot the BCM and see what happens. If you don't get the desired result, change it back.
Ford Bronco Sport Full view not available (rear view camera) 1772754274522-l3
In my F150, it also shows "disabled" but the tag lights are on when I reverse. I can try changing it to enabled on my truck to see if the behavior changes and report back if you're not in the mood to FAFO. 🤣
rugedraw
Javier
Miami, FL
I tried it on my F150. Tag lights still came on in reverse. I noticed no differences in behavior. I changed it back to a 0.
Unicorn
Chester
W. WA
BS Badlands with Sasquatch.
It would make so much more sense is Ford had put that on the left or right where you choose the camera, or where the 360 view is.
Raven
Raven
PA
Thanks so much for that info Javier!
So lines 0, 2, 4, and 6 are disabled. Do I need to enable all 4?
Raven
Raven
PA
Sorry, I just read your previous post, I understand now.
Thanks much!
MB_Ray
Winterpeg
2025 Big Bend Black Diamond
Will they remove that banner on Forscan at the dealership? I don't want to have to buy a Windows laptop and the software just to get rid of that stupid banner.
Thanks,
