The dealer told me $215 I used my ford points for it.I may have overlooked this, but what is the ballpark price for these components (or MSRP)? Thanks
Check out the f
Sorry, I'm confused. I have remote start from the factory on my fob. Should I connect the jumper?Aloha Big K!
The remote start feature can be enabled or disabled on the unit via a jumper that comes with the unit. My FE too already had the remote start on the FOB.... So I kept the remote start enabled on the alarm... Nothing changed still works as it did before.
You can also adjust the sensitivity. I set it high... Funny story.. My daughter's friend come over and she bumped her front bike tire into my front tire... The alarm set off immediately.. Scared her.
If I bump my fist on the body it gives a short honk... So it works great.
I finally had the dash cameras installed and they work along with any alarm... Heads up if you get the rear camera.. If you don't unlock the tail gate but only touch the handle to keyless entry . The motion of the camera moving up sets the alarm off. FYI
Presumably it does, just not one that does perimeter/glass breaking sensing from factory (e.g. attempting to open doors once locked would probably trigger alarm).Wait, does the BSBL not have a alarm already built in? Or is this thread for the other models that may not have it?
Interesting. I figured for such a high trim model, something like this would already be included, but perhaps not.Presumably it does, just not one that does perimeter/glass breaking sensing from factory (e.g. attempting to open doors once locked would probably trigger alarm).
Securilock is standard. The perimeter alarm is an upgrade.Presumably it does, just not one that does perimeter/glass breaking sensing from factory (e.g. attempting to open doors once locked would probably trigger alarm).
BL + has everything except the "shock sensor/broken window" portion. If you want to add this AND HAVE remote start already, there's a dip switch setting. Otherwise, this also adds remote start to non equipped vehicles. Did this to my 2018 F150...Interesting. I figured for such a high trim model, something like this would already be included, but perhaps not.
Sucks... It seems that the word is already out to break the window to get into Bronco Sports. It already happened to my 2023. Shame on Ford. For the price tag, a sensor alarm should be included. Yes, I know, it's 2023 and consumers pay more and get less. My bad.BL + has everything except the "shock sensor/broken window" portion. If you want to add this AND HAVE remote start already, there's a dip switch setting. Otherwise, this also adds remote start to non equipped vehicles. Did this to my 2018 F150...
